C4 Starting Issues When Warm
Old Sep 24, 2007 | 03:31 PM
corvette85guy's Avatar
corvette85guy
Default C4 Starting Issues When Warm
Question for you folks out there: I have an 85' vette with the 4+3 with 60K on it. It starts up like a champ every time except when I've been driving it for a while. If I driven it for a bunch of miles regardless of how I'm driving it, immediately after shutting off the motor and then trying to fire it back up all I get is the fan that kicks on and no crank from the motor. I decided to open up the hood on my car and let the hot air from under the car get out for a few minutes and literally after 5 minutes I was able to start the car perfectly. Now I have another buddy who has an 81 vette that does the same thing.
Is this something characteristic to the vehicle line?
Any ideas as to where to start?
I just threw a new battery and belt into it and I'm looking into an exhaust wrap to try and keep some exhaust heat out of the engine compartment but what else?
Thanks in advance!
Old Sep 24, 2007 | 04:16 PM
Muffin's Avatar
Muffin
Very common with large 350 starters that have a bit of age on them. problem is in the brass contacts in the solenoid. The become burned from use, when hot don't make sufficient contact to carry cranking current. You can do several things, best solution is a mini starter, new starter,new solenoid, or rebuild the solenoid. My solution was a mini starter.
Old Sep 25, 2007 | 03:02 PM
corvette85guy
I figured it had to be one of those also. Now what do you mean by a mini-starter? I had figured replacing the solenoid switch would do the trick but I'd be interested in the mini starter also depending on how you felt about your experience.
Old Sep 26, 2007 | 09:50 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Mini starter is a gear reduction type, it's a lot smaller in size compared to a normal direct drive starter.
It does sound like your starter is the problem.
Old Sep 27, 2007 | 12:17 AM
jfb's Avatar
jfb
You can replace just the solenoid contacts. If you can't hear the solenoid click when you hit , "crank", on the ign sw, then you might have poor battery connections which you can fix by cleaning them. If you do hear a click, if you keep cycling crank over and over and if it starts, you have banged the contacts enough to get the starter to run and this also tells you the contacts need replacing. I had this happen to me about 6 months ago and it took 20 crank hits to get my starter to crank.
To C4 Starting Issues When Warm
