1985 C4 questions
Old Sep 28, 2007 | 09:04 PM
Rick84Vette's Avatar
Rick84Vette
Default 1985 C4 questions
I am an old timer in muscle cars of the 60s and 70s but new to the Corvette world. I bought an 1985 Corvette as a cheap project. Previous owner said it ran but idled roughly. I have been unable to get it started. It has 35 lbs of pressure at the fuel rail. I tested each injector with a noid light and they are firing. I pulled a plug and grounded it and the plugs are also firing upon cranking. It cranks very well and builds 10 lbs of oil pressure while cranking. The security light flashes on the instrument panel but I think in 1985 the only security was to blow the horn if disturbed.
Questions:
1) Can you "prime" a TPI engine with starting fluid?
2) Any ideas why it won't start?
Thanks for any help!
Old Sep 28, 2007 | 11:11 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default security?
Since you have mentioned it has fuel pressure and spark with a flashing security light I would have to guess that something may have activated the ingition lock feature of the security system. Since you mentioned the horns are not honking, try this test, activate the horns manually at the steering wheel and see if they work. My 85's security system would not honk the horns many years ago because part of the manual horn honker under the steering wheel cap had broken. Saw the problem when I removed the cap. Fixed it and the horn honked manually and with the security system. Without getting out my owners manual or service manual, I am pretty sure the car becomes a no starter when the security system is activated. Try locking and unlocking the drivers door to get cancel the blinking security light. One thing I have learned to do with my 85 to give me instant starts either hot or cold engine is to turn on the ignition, listen to the fuel pump relay click to verify that the fuel pump in the tank just put fuel pressure in the system and then start the car. Giving the system about 15 seconds to be ready, my 85 just starts when I turn the key to the start position, saves wear and tear on the starter for sure.
Old Sep 28, 2007 | 11:38 PM
Demonic85's Avatar
Demonic85
Welcome to the world of fuel injection, it sucks. Security light? Are you sure its not the check engine light? Yes you can shoot some starter fluid into the intake to see if it'll start that way. Be careful though cause unlike a carbed engine it may backfire with a fireball out of the intake if you spray too much, ask me how i know
The first thing i'd do is check for codes. You can do this using a paper clip or just a short length of wire. Locate the ALDL connector under the driver side dash. Put one end of the wire into the top right pin and the other end in the one right next to it. Then turn the key to on, but dont crank it. The check engine light will flash, Once, then 2 flashes, thats a code 12 and it will repeat 3 times. What your looking for is anything other than code 12. Alright well theres a lot more to it than just the fuel system and spark. You should also check the MAF sensor, mine was broken and flooding the engine so bad it would barely start.
Old Sep 29, 2007 | 12:41 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
On an '85 the flashing security light is normal when the doors are not locked. When you lock them the light will come on steady until you shut the doors.
As far as the no-run situation, since you have fuel pressure and spark I would check compression. Has the car sat a long time? Is there a possibility of collapsed lifters? Also check for codes as 4Ever21 stated. Pull the pass side valve cover, (the drivers side is a beach) and check rocker movement. Do these things then let us know what you find.
Old Sep 29, 2007 | 12:51 AM
The Beep's Avatar
The Beep
If it turns over, it's probably not the security system. .02
Old Sep 29, 2007 | 09:16 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Do ALL the plugs get wet from fuel ?? Maybe you have one or more stuck injectors.
Old Oct 2, 2007 | 05:24 PM
Rick84Vette
Here is what I have tried so far with no luck:
- Diagnostic computer codes flash 12 then 12 (this indicates ECU is
functional and has no stored error codes)
- Fuel gauge placed on fuel rail jumps to 35 lbs once ignition key is
on (within specs)
- Noid lights placed on fuel injectors all flash indicating computer
is firing injectors
- Coil is 12V hot once ignition is on
- Pulled plugs are clean and non corroded, lightly moist with fuel
- Spark plugs pulled and grounded fire upon cranking (indicating
working coil and distributor)
- Battery is strong and has great cranking speed
- Mass Air Flow sensor indicates correct voltage
- I have tried unhooking MAF which forces ECU to use a default
reading. No luck.
- I have tried a shot of starting fluid into the airstream. No luck.
The search continues. Next step is to start running diagnostic jumper
tests on the ECU and various sub components. I will run compression tests.
- It just makes no sense to me that it does not fire at all. I have
learned more about fuel injection in that last two weeks than ever.
Old Oct 2, 2007 | 05:35 PM
Chatman's Avatar
Chatman
Check firing order and rotor/cap position. Go to compression on one, remove cap and check rotor position. It sounds like the wires are scrambled or 180 off.
Old Oct 2, 2007 | 05:47 PM
Jer's Avatar
Jer
Pull plug number one, stick finger in and have friend crank to find top dead center, check orientation of rotor. Make sure it is pointed close to terminal number one.
Old Oct 2, 2007 | 07:41 PM
AGENT 86's Avatar
AGENT 86
Maybe the previous owner was a ford guy
Old Oct 5, 2007 | 09:37 PM
Rick84Vette
Update: The firing order is correct. I checked a couple of cylinders for compression and they were both over 150psi. I am at a loss and really getting frustrated.
Old Oct 5, 2007 | 10:18 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
Fuel - Check
Fire - Check
Codes - None, yet.
Unless you have a tankfull of water, it sounds like timing is way off. With #1 @ TDC, where is your timing mark?
Old Oct 6, 2007 | 10:54 AM
70ZZ3 96LT4
Default No start
Rick you have checked out a lot on the car. Another option is to call Gordon Killebrew and spend a few dollars on his trouble shooting expertise service. He also runs a school for tech information on working on our C4's. I hope to take my 85 to Gordon's School one day, it is in Cross Plains, TN. He was at Mid America's Funfest in Effingham,IL last month and had free tech sessions with questions from the audience. Hope he is there next year. His phone is 615-654-2864/ 800-F-Y-VETTE.
Old Oct 6, 2007 | 12:43 PM
Muffin's Avatar
Muffin
Originally Posted by williammackean
Fuel - Check
Fire - Check
Codes - None, yet.
I ran into something like this last year. I had screwed up timing so bad car wouldn't fire. Check the timing, all components to include rotor position vs TDC.
Old Oct 6, 2007 | 04:26 PM
Midnight 85
You said the previous owner claimed it ran but idled rough, did you ever hear it run or did you buy it without hearing it run? I'm asking this because I'm leaning towards the timing too, it's about all that's left. Maybe the guy messed with it trying to make it better and got it all out of whack. Get the mark on the balancer lined up with the "zero" on the timing tab, then pop the distributor cap. The rotor should be pointing to either number one terminal or number six terminal. If it's any place else at all then you need to verify true tdc and set the distributor in properly and make sure the wires are all in their proper position.
To 1985 C4 questions
