window regulator
Old Sep 30, 2007 | 03:00 PM
Blownlt1's Avatar
Blownlt1
Default window regulator
84 coupe
My passenger side window regulator is broken. The motor and guide work, but the teeth or belt that raise and lower the window are broken, can i buy just the belt of chain, or whatever it is i need. If so where and how much?
thanks ,
Muffler
Old Sep 30, 2007 | 03:17 PM
The Batmobile's Avatar
The Batmobile
Originally Posted by Blownlt1
84 coupe
thanks ,
Muffler
What you need is a window ribbon. You get them at Ecklers for like $20. I have to go outside and replace mine after the Cowboys game.
Old Sep 30, 2007 | 03:18 PM
Blownlt1's Avatar
Blownlt1
would an autozone or advance auto parts carry them?
Old Sep 30, 2007 | 03:35 PM
staugur's Avatar
staugur
NAPA has them,just bought two.Very common part,try autozone or advanced if you don't have napa.$20 and a great couple of hours
Old Sep 30, 2007 | 04:26 PM
glide's Avatar
glide
St. Jude Donor '13,'19
If you're going to all the trouble to get to the regulator out you probably should upgrade to the 86+ scissors style. I did and they are fast and foolproof. You can find them in the parts section of this forum. Good Luck!
Old Oct 1, 2007 | 07:01 PM
Blownlt1's Avatar
Blownlt1
you say that napa has the track, but i was just at a napa and they didnt have them in their catalog.
Old Oct 1, 2007 | 07:11 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
84-86E design is crap. It sounds like you're about to spend 2 hours of your time and end up with disappointing results.
http://webpages.charter.net/khasting...windowreg.html
Old Oct 1, 2007 | 07:31 PM
CFI-EFI's Avatar
CFI-EFI
Many auto parts stores carry the nylon or plastic window regulator ribbon in the "Help" brand line. Instead of in catalogs (or on the computer) it is on display in the front of the store. It is listed to fit a Dodge or some Mopar van. It works like a charm. Just be sure to cut it to length before you reinstall the door panel.
RACE ON!!!
Old Oct 1, 2007 | 10:02 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
RACE ON!!!
Go to the "Help" section and match up your ribbon to the Chrysler one. It's in stock, in my town of 10,000.
Old Oct 1, 2007 | 11:07 PM
staugur's Avatar
staugur
RACE ON!!!
Dead right on both.Make sure you cut it.It's much too long and if you fit it with the window half way(which I found the easiest) after you put it all back together the window won't go down all the way and it will bind up.Push the slide all the way up the column and cut it 2 or 3 inches from the gear drive on the motor.
Old Oct 2, 2007 | 12:11 PM
Blownlt1's Avatar
Blownlt1
thanks for all of your help, luckily it has been sunny and hasnt rained, i went to ecklers and the ribbon got her today, thanks again
To window regulator
