Timing chain problem: HELP!!!!!
Old Oct 19, 2007 | 11:48 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
Originally Posted by jsup
What's that big extra gear for in front? It has nothing to do with a chain.
My bad! I forgot yours was an L98 - Sorry. This is the backside of the LT1 timing set.
Old Oct 19, 2007 | 11:52 PM
Demonic85's Avatar
Demonic85
If you click on the application link on the bottom it shows its for vented Opti LT1.
Old Oct 19, 2007 | 11:53 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
So now we have a 1/2 dozen possible part numbers. WTF am I supposed to use?
Old Oct 19, 2007 | 11:57 PM
Demonic85's Avatar
Demonic85
The part number 9-3064K is the one that you said fits. Its just like the stock one and that one fits right? Of course there are other versions of it like double roller, billet, etc.
Old Oct 20, 2007 | 12:06 AM
rrubel's Avatar
rrubel
I bought a semi-generic true-roller set from Competition Products for my 74219 cam on my L98 engine. Heavy-duty, billet, overkill, but it was FAR cheaper than something through Summit. It was either this one:
http://www.competitionproducts.com/p...?number=CP1001
or this one:
http://www.competitionproducts.com/p...?number=CP1000
[RICHR]
Old Oct 20, 2007 | 12:18 AM
STL94LT1's Avatar
STL94LT1
Originally Posted by 4Ever21
That one is for a V6
The Cloyes 9-3145 will also work on a V8, I'm running one in my LT1. I don't see why it wouldn't work on an L98?
Old Oct 20, 2007 | 12:30 AM
Demonic85's Avatar
Demonic85
I take it you got rid of the Opti and went with a crank trigger then? That one doesnt have the gear for the Opti.
Old Oct 20, 2007 | 12:48 AM
STL94LT1's Avatar
STL94LT1
No, I'm running a Gen II opti, it is driven from the camshaft's dowel pin. Also LTx's have to run an electric water pump with the 9-3145.
Old Oct 20, 2007 | 12:57 AM
ultraviolet70's Avatar
ultraviolet70
Well I've got a factory roller cam on the shelf and a Cloyes 9-1145. I can go verify if the mounting holes line up between the cam gear and cam.
Old Oct 20, 2007 | 01:23 AM
ultraviolet70
Found it.
The cam gear from CLO-9-1145 matches up fine with factory roller cam. Assuming your cam is true factory style roller I would think this timing chain would work. Of course you know from my thread (that you posted in) that Summit states that it won't fit behind the factory timing cover, but it a few people already posted that info was B.S.
Old Oct 20, 2007 | 06:19 AM
mseven's Avatar
mseven
The number ultraviolet posted is what I have. Cloyes also has very good tech. assitance, if you need to talk to someone who actually knows what fits....instead of summit.
Old Oct 20, 2007 | 07:49 AM
rodj's Avatar
rodj
"Summit states that it won't fit behind the factory timing cover, but it a few people already posted that info was B.S."
Physically the roller cam / non roller cam timing sets are the same.
The difference is the clearance behind the top sprocket for the two bolts that hold the cam retainer plate on the roller cam engines.Roller cam sprockets are machined differently to clear bolts
Old Oct 20, 2007 | 02:53 PM
  #33
jsup's Avatar
jsup
Still, no answer from Jegs. I am hesitent to order anything at this piont and will just call Cloyes on Monday.
Old Oct 23, 2007 | 09:44 PM
  #34
jsup's Avatar
jsup
Found it.
Thanks, I'm ordering the 1145 now.
Old Oct 24, 2007 | 08:49 PM
  #35
ultraviolet70
Keep us posted. I'm curious about your results.
Old Oct 24, 2007 | 09:50 PM
  #36
JAKE's Avatar
JAKE
It would have been nice if you had posted what year engine we're dealing with. Is yours a Gen I or Gen II? If a Gen II is it a 96 with a Crank Position Sensor?
I just went through this timing chain problem a few months ago when builidng a 388 for my 96 LT1 Vette. The Cloyes True Roller I originally bought wouldn't fit behind the timing chain cover without eliminating the stock water pump and installing an electric pump. I ended up selling it to another Forum member.
Buy one that's specifically for your engine; not one that "should" work.
Read the specifics of the T/C set entirely. Summit's site has a link. Some will say "Will fit 85-99" and that ain't so. I've emailed a few different sites about such mis-information.
Jake
Old Oct 24, 2007 | 10:07 PM
  #37
jsup's Avatar
jsup
Jake
I'll know by Friday. I called Cloyes and went through the application with them, 1990 L98, factory roller cam.
Cloyes gave me the numbers.
To Timing chain problem: HELP!!!!!
Old Oct 26, 2007 | 09:07 PM
  #38
jsup's Avatar
jsup
I got the 1145. It fit.
Saga over.
Old Oct 26, 2007 | 09:09 PM
  #39
jsup's Avatar
jsup
Jake
BTW Jake,
Following the application guide, I got it wrong, the "experts" at summit got it wrong, and the "experts" at Jegs got it wrong.
There's a lot of choices and it's not clear on the websites of Summit or Jegs which is which.
Old Oct 26, 2007 | 11:52 PM
  #40
ultraviolet70
Saga over.
I guess it fit under the timing cover-contradictory to what Summit says.
