Chasing the threads
Old Oct 27, 2007 | 10:23 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Chasing the threads
Can I chase the threads by cleaning up the old bolts and putting "slots" in them (kinda like a tap)? Do I need actual "thread chasers". That's a trick one of the machinist taught me in one of my jobs I had while in college.
Finding a thread chaser locally is getting to be a bitch. I really won't need them after this build, so there's no point in spending tons of money on "top of the line" ones.
Summit has a set for $12, however, they just look like simple threads to me...
The threads in the block aren't beat up, I just want to clean them before I put them together.
Old Oct 27, 2007 | 11:44 PM
Carpenter's Avatar
Carpenter
Buy two sets of tap/die sets (Metric and Standard) for about $14.00 each from NAPA. They'll last you for years.....AND you'll find lots of other uses for them also.
Poor quality, sure....but GREAT to have around.
Old Oct 27, 2007 | 11:52 PM
jsup's Avatar
jsup
A tap and a chase are two different things. A tap can cut, a chase doesn't.
I have taps. I need a chase.
http://buy1.snapon.com/catalog/item....re&dir=catalog
http://store.summitracing.com/partde...5&autoview=sku
Old Oct 28, 2007 | 12:27 AM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
You think these are ok - or junk? They look like pot metal, but they might be good for a couple uses.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SUM%2D9 00200&N=700+4294853264+115&autoview=sku
Old Oct 28, 2007 | 12:34 AM
jsup's Avatar
jsup
Those are the ones I'm looking at. I figure if I get one use out of them they're worth it.
This is why I'm thinking of taking an old head bolt and cutting into the threads. I did it for a sparkplug hole once, and it worked fine. At that time, I had access to a mill, I don't today. I'm going Dremel.
Old Oct 28, 2007 | 12:49 AM
biggrizzly's Avatar
biggrizzly
Let me know how this goes, I got to chase all my holes too.
I'm a little behind you on the reassembly, waiting for my heads to get here.
I still got a ton of stuff I want to clean up in the engine compartment before I really get started putting things back together.
Old Oct 28, 2007 | 12:52 AM
black88z51's Avatar
black88z51
i used a tap & die on my head bolts and block threads. the threads had alot of old thread sealent on them and the block had a thread that was begining to decay. this made assembly and torqing down easier.
Old Oct 28, 2007 | 12:54 AM
jsup's Avatar
jsup
PM sent, put on a Chicken Suit and call me Monte....
Old Oct 28, 2007 | 01:03 AM
jsup's Avatar
jsup
Last resort using a tap. I'd prefer not to cut new threads as there's no telling if the bolts would react negatively or not. I don't want to cut more out than is necessary.
Old Oct 28, 2007 | 01:11 AM
biggrizzly's Avatar
biggrizzly
Too funny! I'll take door number three please... Monte!
Old Oct 28, 2007 | 08:17 AM
Muffin's Avatar
Muffin
I have a set of those I have been using for years. Haven't failed me yet.
Old Oct 28, 2007 | 09:13 AM
JohnyH's Avatar
JohnyH
That's the way to go!
Old Dec 11, 2007 | 06:35 PM
thirdtimevetteowner's Avatar
thirdtimevetteowner
I can't see how the cheap Summit set could possibly go deep enough to chase all of the threads, when comparing them to the ARP set.
Old Dec 11, 2007 | 07:07 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Yes you can take a cutting wheel and cut slots in the threads. Just make sure you take a wire wheel to it first to remove any burrs.
Old Dec 11, 2007 | 07:29 PM
jfb's Avatar
jfb
Running a tap into a threaded bore should not do any, "cutting", and I don't see anything wrong with that practice. Use some oil on the tap so you don't gall the threads. Junk filling the threaded bore will be removed by the tap.
Old Dec 11, 2007 | 10:09 PM
scott85vette's Avatar
scott85vette
I agree,a tap can be used for cutting new threads or chasing old threads.
Old Dec 11, 2007 | 10:25 PM
jsup's Avatar
jsup
If that were the case, why are chases even made?
BTW, I'm done. The threads were chased, then followed with a clean bolt before I bolted everything up.
Just wonderin' if there really is no need for a chase, why is the practice recommended by every engine builder I spoke to?
In fact, one went as far as to say "make sure it's a CHASE not a TAP".
To Chasing the threads
Old Dec 12, 2007 | 12:18 AM
LarryK 87's Avatar
LarryK 87
Have always been curious about that myself
Old Dec 12, 2007 | 12:32 AM
evmlarry's Avatar
evmlarry
I honestly have never had any issues using my taps to clean threads. Everything has always snugged up and torqued down fine for me. It's just one way I've learned from being around working on cars and large machinery with my dad growing up.
Old Dec 12, 2007 | 12:39 AM
KeyWestJack's Avatar
KeyWestJack
