Bad ECM?
Old Nov 13, 2007 | 11:15 PM
bfreidt's Avatar
bfreidt
4th Gear
Default Bad ECM?
Hello everyone! Newbie here!! I have a 86 automatic coupe. On the way to the store the engine just died. Tried to start a few times and the starter just cranked, could'nt get it to fire. Popped the hood and looked around for anything obvious, nothing. Got back in the car tried again and it fired right up and ran fine back to the house(approx 10 mi). Next morning tried to take it to work but got around the corner and it died. Same thing tried a few times nothing, waited a while and it fired up. Drove car home, shut it down and tried to restart it, nothing. Now it wont start even after letting it set for a while. No check engine light through all of this. Even so, I jumped the computer for any possible stored trouble codes, I didnt get any diagnostic code reaction, not even the first series of 12-12-12(system operating correctly code). I checked the jumper to make sure I had a good connection and I did. I have jumped codes in the past and every time I got the 12-12-12 (system operating correctly code) followed by the stored codes. I will have to wait until tomorrow to do more extensive troubleshooting, spark, fuel delivery and so on. However if the ecm is bad there is no sense in troubleshooting any further. Any suggestions??
Thanks.
Old Nov 13, 2007 | 11:40 PM
Siveck's Avatar
Siveck
Bad injectors can cause intermittent problems. With the ignition off, pull each injector plug and measure the resistance across the two injector prongs. They should all be near 17 ohms or so without any being very different. Try this cold and then hot to make sure that nothing changes with heat.
But first, try the basics like you said. Put a fuel pressure guage on the shrader valve and monitor for proper readings at around 39 psi or so. Put a timing light lead on a plug wire to check for spark when it won't start.
Old Nov 19, 2007 | 11:48 PM
bfreidt's Avatar
bfreidt
4th Gear
Hello all
I am still having problemsgetting the 86 coupe started. Just a quick question for all the ecm gods!!
If the "service engine soon" light is non-responsive in any key position, whether in the "on" or "run" position and also non-responsive in the diagnostic mode (with jumper wire in place). Does this mean the ecm is bad??? Checked for a burned out bulb or a bad bulb connection and everything is good.
Old Nov 20, 2007 | 01:07 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Being new a good thing to learn is to use the Search function, main menu bar, Advanced, Include Archive posts and search the C4 forums... Theres tons of info and good material, another place is the C4 Tech Tips, Read and learn... Also since it hasn't been said already, get the FSM (Helms) manual, you'll need it.
Old Nov 20, 2007 | 08:11 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/No...0-%20Light.pdf
Old Nov 20, 2007 | 01:22 PM
bfreidt's Avatar
bfreidt
4th Gear
Thanks for the quick response and the troubleshooting schematic!!!
Going back out to do more troubleshooting!
What manual did that schematic come out of? Where can I get my hands on one of those??
Old Nov 20, 2007 | 03:14 PM
AGENT 86's Avatar
AGENT 86
Factory service manual, available used in the for sale section here and Ebay. New ones here... http://www.helminc.com/
Old Nov 20, 2007 | 03:15 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Fill out your user profile information....
Old Nov 20, 2007 | 03:20 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default 86
I had the exact same thing on my 86. change your starter.
The plastic starter brush holders shrink when cold, and expand when hot pulling the starter brushes off the commutator, and won't let the starter turn. I start it up, drive 1.5 miles to the store, shut it off, buy milk, get back to the car, and nothing.
Lights switch over to the start mode, everything is fine.
an hour and a half, 2 hours later..........vroooom, starts right up.
I went through the vats thing, the neutral start switch, the fuel pump, the distributor, etc. finally pulled the starter after checking it for volts when I turned the key.
change your starter, or rebuild it. my 86 thanks me for it every day.
Old Nov 20, 2007 | 03:52 PM
Vetracr's Avatar
Vetracr
Its an 86 with VATS. No start / wait / start is symptom of VATS problem, might need new ignition key with upgraded resistor. Its a common problem on 86's.
Larry
Old Nov 20, 2007 | 04:41 PM
airblaine's Avatar
airblaine
Agent 86
you made that too easy, you should be ashamed
Old Nov 21, 2007 | 08:36 PM
bfreidt's Avatar
bfreidt
4th Gear
Default Its fixed!!!!!!
Thanks to everybody for all the help!!!! Went out and checked the cluster of fusible links and found one that was bad, all full of corrosion. It was the battery feed to the C16 pin on the ECM. Replaced it with a new fusable link and all troubles went away!!
To Bad ECM?
