Pushrod length dilemma
The measuring pushrod, set at 6.950":
The position of the rocker tip in this configuration (no pre-load):
Another valve with the same pushrod length, this time after the 'pen on the tip' technique:
The amount of material taken from the base of the rocker arm:
..and the resulting clearance (with preload) at the stud (need to look closely)
I may not go with the lash caps approach - I would need to get new valve stem locks and retainers to get them to fit. I'm reasonably confident with the 'remove material' technique.
Paging "rklessdriver" - is this approximately the LITTLE that you referred to?
Thanks!
http://cranecams.com/?show=browsePar...Number=99473-1
And you need a compressor to pressurize the cylinders with in order to remove the valve keepers.
I can tell from the pics he has 7 degree locks and retainers. The only locks cut with a relief for lash caps I know of are 10 degree. The lash caps would be a fine solution to this problem thou, provided he was willing to buy new 10 degree retainers and locks (and hadn't already modified one of his rockers).
djxib
IMO The amount you have removed from that rocker will be fine. It won't hurt anything. I pulled a Batten headed Olds drag motor apart (I did not build it orginally) last year for a friend of mine with the same type Harlan Sharp rockers that had about 3 times that amount taken off the bottom. Rockers were 6-7 yrs old then and are still running fine.
Will
Will
Cheers
