Solid Rear project started! WOOHOO! Pics inside . . . .
Old Jul 24, 2008 | 10:38 PM
  #221
AKS Racing's Avatar
AKS Racing
The solid rear project turned out AWESOME! Now you just need the engine to back up the killer looks.
Very Nice!!!!
Old Jul 24, 2008 | 10:40 PM
  #222
DVNCI's Avatar
DVNCI
Very Nice!!!!
on both counts.
Engine's gonna have to wait a while though!
Old Jul 25, 2008 | 09:26 AM
  #223
LT4POWR's Avatar
LT4POWR
I can't wait to see more pics.
ps...damn that rear is low
Old Jul 25, 2008 | 10:05 AM
  #224
AKS Racing's Avatar
AKS Racing
You need to update your avitar with "the new look".
Old Jul 25, 2008 | 10:11 AM
  #225
DVNCI's Avatar
DVNCI
It's probably not quite as low as it looks in that pic, once you see it sitting on level ground you'll see the car still has a slight rake to it. What makes it look even lower though is because that's a pretty tall tire, 345/30/18, so the tire fills up the well. Eventually I'm going to put some coilovers up front so I can pull it down just a little up there to really get the rake I want. We can't go much higher with the rear.
Yeah I've already thought about that!
Old Jul 25, 2008 | 06:50 PM
  #226
DVNCI's Avatar
DVNCI
FYI just added a bunch more pics on page 11!!!!!!!!!!
Old Jul 25, 2008 | 11:29 PM
  #227
-=Jeff=-'s Avatar
-=Jeff=-
I wanna see more pictures of the dash and gauges
Old Jul 26, 2008 | 08:39 AM
  #228
DVNCI's Avatar
DVNCI
I'll probably get some more of those up later but did you see page 10? There are quite a few pics there of the dash/gauges. I'll get some more interior stuff up before long probably.
Old Jul 27, 2008 | 09:39 AM
  #229
-=Jeff=-'s Avatar
-=Jeff=-
Yes, but always cool to see the finished dash too
Old Jul 27, 2008 | 10:20 AM
  #230
DVNCI's Avatar
DVNCI
It's basically finished in those pics you see but we still have a lot of work to do, especially wiring!!!!!!!!!!
Once I get all the wiring done I'm probably gonna dynamat everything, then recarpet, and then I'll get some more pics up!
Old Aug 1, 2008 | 04:02 PM
  #231
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default car
what r you going to do for exhaust?
Old Aug 1, 2008 | 05:26 PM
  #232
DVNCI's Avatar
DVNCI
It's on there:
http://home.insightbb.com/~kevin.ale...r/IMG_1544.JPG
In that pic you can see the mufflers, which had to be shortened, you don't see the tips in that pic but they now both come out right below the differential. It's really clean that way
Old Apr 1, 2009 | 01:33 PM
  #233
tachout's Avatar
tachout
That is one sweet project. This thread is saved in my favorites now. I am not only going to keep a watch on your project, but plan on taking some of the references for my own. I am working on a 90 C-4 and plan on a full 12 point cage, solid axle rear, and redoing the entire interior some too. My project is getting a twin turbo, intercooled, meth injected, with NOS engine. Not sure on the trans yet, (But we know the 700R4 is not going too be in there). The goals for my project are pretty lofty.
1. I want a sub 10 second car here in Utah
2. I want to see over 1000 HP on the dyno with it set of Kill
3. I want it to pass Smog here
4. I want it to be streetable.
Keep in mind that I will be able to remove the NOS (300 Shot) and turn down the boost hence the streetable. And I work and live about 10 minutes apart, and driving it to work or on a cruise is the idea of streetable. Very lofty goals and I might not make most of them, but one way our another it is going to be a fun build. Hope mine turns out close to as nice as yours is.
Old Apr 1, 2009 | 04:20 PM
  #234
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Came out real nice
Old May 4, 2009 | 07:21 PM
  #235
DVNCI's Avatar
DVNCI
Thanks guys, hadn't been on here in a while.
Basically I started rewiring the entire car but just tore my knee up so that put a damper on that for a bit. Hopefully by this fall it will be 100% done, interior, stereo, wiring, everything.
Old May 4, 2009 | 08:25 PM
  #236
383vett's Avatar
383vett
Looks like your project worked out great. How is the ride with the straight axle in the back? I didn't real all the previous pages. Do you have a spool or a posi? I'm surprised with the coilovers you can't raise the back more just in case you wanted to put a larger slick back there. Good job! Willie
Old May 5, 2009 | 09:09 AM
  #237
DVNCI's Avatar
DVNCI
Right now it rides horribly. But that's due to the shocks, need to adjust them.
It's a Detroit Locker, I didn't want a spool as this car will spend a great deal of time on the street (though no rain).
I can definitely raise the rear end no problem, but I want it as low as possible so that's why it sits so low in the back right now. Eventually I will put some big slicks out back.
Right now the front end is kind of high because I need coilovers up front to get the stance where I want it.
To Solid Rear project started! WOOHOO! Pics inside . . . .
Old May 5, 2009 | 12:10 PM
  #238
383vett's Avatar
383vett
I've got double adjustable coilover Varishocks in my back. They have a 16 click adjustment range. I have the compression at 12 and rebound at 5. Works fine for the track. No street driving though.
Old May 5, 2009 | 12:28 PM
  #239
"J"'s Avatar
"J"
From: Bardstown ( Bourbon capitol of the world ) KY ( The Bluegrass state )
Dude those are some nice gauges . Its really going to set the inside of your car off, nice choice.
An what is that blue bottle sitting beside the car Does somebody have something up there sleeve So how does it sound with the muffler's cut? Nice work man, I can't wait to see it
Old May 5, 2009 | 07:24 PM
  #240
JackDidley's Avatar
JackDidley
Yea, I think you're just dragging this out to keep us in suspense.
