My old schooling was to re-torque steel gaskets and it was not needed on the composites because they were more forgiving. It has been awhile since I installed a set of heads but I am sure I will follow the gasket manufactures recommendations when the time comes. Later! Frank
I had not. I just set the base timing to 6* btdc. However you bet I will on my 3rd go-around.
Datamaster is your friend. Tunerpro RT is free. Not bad either.
I remember your previous thread about the gasket problem but not details. Who burned your chip ?
Be safe. Get a low buck laptop and Tunerpro TR or Datamaster. Tunerpro is free and you can use Datamaster 20 times free. After that its $120 for unlimited use. It has paid for itself many times for me. Its also a very intresting tool to use.
Hey Chuck, I didn't mean to insinuate you didn't do it in stages or follow the pattern....sorry if it sounded that way, what I was trying to emphasize was at least in my experience and being of "old school" I still believe in retorquing after bringing the engine up to temp. I've only had one experience where I had to do it again (head gasket) and that was on an old Jag. (aluminum head also) I thought I had carefully checked the head (with a straight edge) so I didn't think it needed resurfacing...boy was I wrong.
At any rate 2 of us checked the heads and the deck surface with a straight edge.....and as far as we can tell....she looks good.
as long as it's .002" or less front-to-back and side-to-side, you're good to go.
as for fel-pro, i hope that if they're at fault, then they admit it, man up to the plate, pay for a new set of gaskets and at least pay some portion of the labor costs.
in this day & age, that sort of honesty & forthrightness is few and far between.
Had a very similar experience with the FelPro 1010 head gaskets. Turns out my tourque wrench was 10ft lbs low. However I switched them for the thinner Victor Reinz? 5746 gaskets and never had any more trouble.
Understood.....it's a good read for "old school" practices that may just help somebody out in the future.
I am going to have my torque wrench re-calibrated before I attempt this again. I had mine and a buddies of mine which torque values seem to be almost dead on. The could both however be f'ed up.
and don't ask me how i know.
I have had a few dealings with felpro over the years. I can say that they are an honest bunch. I strongly suspect that they will give a straightforward, factual evaluation of the failed gaskets. I have seen them pay for gasket failures if the problem was related to them.
If I were going with a high compression engine like that I would build it overkill with the gaskets. The 1010's are strong for a stock or mild engine, but I have no idea how well they hold up on an engine like that.
I still can't get used to 11-1 being called high compression.
C'mon guys.... 12, 12.5 is considered high.
11-1 shuld be considered a mild build for a gasket manufacturer.
