Update on Blown head gaskets
After the failure of my 1010 gaskets with TFS 23d heads, I used FelPro 1003 which was recommended by BOTH AFR and TFS. The .002 diff in thickness was negligible in CR. My motor was about a 10.3:1 with the 64cc chambers and stock 9:1 pistons of my 84. I had run the motor about 5k miles when I started having problems.
I learned from 3rd Gen that the 1010 had a rep for fire ring separation from the gasket material.
Read this thread
http://www.thirdgen.org/techboard/te...ht=felpro+1010
Same issue I had with the 1010. No problem with the 1003. Hope that helps.
L98 Head gasket failure question.
Of note are:
- Comments regarding concern about the possibilty of Brinelling
from the 1003. 89 Paul in Cal reports long term 1003 use without issue. - Fel Pro's recommendation of the 7733PT2 over the 1010
Also...
I've been trying to find the maximum compression ratio that the 1010's are reccommended for. Maybe it's just a matter of my 11:1 compression ratio being too high for the 1010's. Agent 86.....I know that you have had success with your 1010's(I've seen the video
Chuck
Also...
Chuck
I will check to see whether I have a new 1010 gasket. Sanding the ring
with emery cloth or sectioning it will reveal whether copper is present
and if it is plated/painted or encapsulated within some other material.
encapsulated would be my choice of words to describe it
He did say that Felpro recommends re-torquing the heads twice for this style gasket. Once after your torqued heads have sat for at least 1/2 hour and once after it has gone through a heat cycle. The procudure is to break the #1 bolt(#1 sequence)loose and torque it to spec. Then break the #2 bolt (#2 in sequence)loose and torque it to spec, following this for all 17 bolts. I don't know how much of a difference it makes in re-torquing them this way as opposed to just setting the wrench to 65 ft. lbs. and tightening the bolts......I didn't do it Felpro's way the first time around but I will this time. Hopefully I'll hear something tomorrow.
Please do not use felpro 1010, reaD THE LINKS on you will learn why.. thanks
following for consideration.
There have been many accounts in C4 Tech of premature head gasket
failure after installing FelPro 1010 gaskets for iron block, aluminum
head combinations. Typically, the fire ring fails between the back two
cylinders (5/7 or 6/8) after a few years.
In just ONE thread, the following members report trouble using the
FelPro 1010 on Fe/Al SBC's. There are pictures of failed gaskets in
the thread.
korvette4u
Dominic Sorresso
Plasticman
Morley (FelPro, but unsure if 1010)
Bogus
HuggerVette
Dissimilar (galvanic) metal corrosion - a basic primer on the subject
Depending on the grade, Aluminum has an Anodic Index of 0.75 to 0.95,
just around the 0.85 index of low alloy Steel.
However Copper has an Anodic Index of 0.35 - far enough along the
scale to cause trouble.
Further reading
After reading the above, if I could only choose between the following
two gaskets for an aluminum head on an iron block, I would choose
the #1003 because its steel ring is galvanically more compatible with
the adjacent materials than is the copper ring in the #1010.
Fel Pro 1010 - SB-Chevy
Copper Wire Ring Head Gasket
SB-Chevy Bore 4.166'' Thickness .039'' Volume 8.9cc
Fel Pro 1003 - SB-Chevy
Steel Wire Ring Head Gasket
SB-Chevy Bore 4.166'' Thickness .041'' Volume 9.1cc
The #1010 may be a perfectly satisfactory choice for an iron head on
an iron block. However, if anyone here would choose the #1010 for a
Fe/Al combo, I would be grateful for a post with a justification for the
selection of this instead of the 1003.
Dominic, When you switched to the 1003 how many miles did you put on it before you sold it?
The reason I went with the 1010 was the thickness. My pistons are .005" in the hole, and I wanted to keep quench under .045"..
-- Joe
-- Joe
-- Joe
-- Joe
I still have the 1003s on my 89. I have about 4,000 HARD miles on it before I pulled the Miniram intake off in favor of a carb set up.
Before my 88 got wrecked, I "re"replaced the leaky 1010 gaskets with 1003 gaskets. I'd say the 1010 gaskets had less than a thousand miles on them before they" blew" again. The 1003 works out nicely for me on the stock 88 motor as well as my 89's high compression built up motor.
