no heat
Heater control valve perhaps.
If the door works, the core is usually plugged up. Try removing the hoses and flushing it with a garden hose or compressed air. Go easy on the pressure as system design is for 15 to 20 psi - though I once unplugged one with a 125 psi blast from my compressor withough putting a hole in it.
If the core is plugged up, the radiator and coolant passageways in the block and heads may be too - so make sure you flush everything - not just the core. Drain the block by pulling the oil cooler hose at the filter (and the knock sensor if you really want to get all the crud out). Of course if you can't get the core unplugged, you'll need to replace it.
.Pakzr is correct, there is no valve on our later 80's model year vettes.
Here are some pics to help illustrate:
the blower module removed
you are looking down into the box to try to see the mix door
In the above pics, the casing is removed, don't remove your casing.
On the inside of the car is another door link. Here are some pics, but keep in mind te entire dash was removed. You would have to try to see it from "underneath" the angle I show in my pic.
Try to see if one of the 2 plastic links is broken or if the core is plugged up.
If those fail, we can see if your controller has a loose solder conection on 2 of it's resistors.
Let us know what you find.
