'89 vette engine removal
Old Jan 23, 2008 | 10:42 PM
willyfastz's Avatar
willyfastz
Default '89 vette engine removal
I'm wondering what's the best way to pull the engine? From the top or from the bottom?
Does anyone know of a good right up? I've done a few searches but didn't really find anything.
Old Jan 24, 2008 | 12:59 AM
rodj's Avatar
rodj
From the top without the trans.
However easiest to remove C beam to drop rear of trans as top bellhousing bolts PITA to reach.Once trans lowered can use extention bar to undo top bolts.
Remove dist , gives more angle before block hits firewall.
Don't forget to undo convertor unless you like big mess on floor.
Taking the wiper motor off gives more clearance for straight lift up..
No need to remove hood
Reverse for install.
Old Jan 24, 2008 | 01:05 AM
bczee's Avatar
bczee
Top is recommended as Rodj stated.. along with his other comments.
You should pick up a FSM or even one of the cheap Chilton.. they have step by step instruction as to what to remove and re-install..
Old Jan 24, 2008 | 08:30 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Old Jan 24, 2008 | 08:39 AM
Iroc57's Avatar
Iroc57
From the top
Probably one of the easiest vehicles you will ever swap an engine in (except for all of the crap bolted to the engine )
Old Jan 24, 2008 | 12:30 PM
HFDFyrefytr's Avatar
HFDFyrefytr
Originally Posted by AGENT 86
As always said, a pic is worth 1000 words! Exactly how I do them.
Old Jan 24, 2008 | 02:43 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
As the picture shows, from the top!!!
Old Jan 24, 2008 | 04:44 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
I find it easier/faster to drop the trans first. Also as above remove the windshield wiper motor or you will break the black plastic cover/controler pulling the engine.
Old Jan 24, 2008 | 08:10 PM
CrippleDave's Avatar
CrippleDave
it took me forever to remove mine, i removed the hood though and it was my first swap, how much easier is it to do it from the side like that?? crazyness
Old Jan 24, 2008 | 09:08 PM
zr1fred's Avatar
zr1fred
Alot easier!
Old Jan 24, 2008 | 11:15 PM
evmlarry's Avatar
evmlarry
Old Jan 28, 2008 | 04:15 PM
willyfastz's Avatar
willyfastz
Thanks for the advise and the pics, I'm just getting ready to start on it now. I'm hoping all goes as easy as it looks.
Old Jan 28, 2008 | 06:14 PM
front royal vette's Avatar
front royal vette
I just did this about two weeks ago, I took off the hood, unbolted the tranny and out it came from the top. I put the new engine in the same way, thru the top. Just take your time, dont rush.
Don
Old Jan 29, 2008 | 06:41 PM
willyfastz's Avatar
willyfastz
I've run into another road block. This car has a nanual trans so just unbolting the trans. and converter are out.
What's the best way to remove the torque arm from the trans. and rear?
Old Jan 29, 2008 | 09:48 PM
willyfastz's Avatar
willyfastz
This has turned out to be the worst engine to pull I've ever done.
Old Jan 29, 2008 | 10:01 PM
AGENT 86's Avatar
AGENT 86
Leave the tranny there unless your planning on rebuilding it. Look at my pic, motor with bell and out.
Old Jan 29, 2008 | 10:09 PM
AGENT 86's Avatar
AGENT 86
To '89 vette engine removal
Old Jan 30, 2008 | 09:17 AM
willyfastz's Avatar
willyfastz
Guess I should have looked at the pic a little closer. I already dropped the trans so I guess now all I need to do is hook up the chain and pick this thing up.
I'm thinking the really hard part is going to be remembering were all the little brakets go when reinstalling it. I may have to buy a book.
Thanks for the help.
Old Jan 30, 2008 | 09:53 AM
AGENT 86's Avatar
AGENT 86
A digital camera is your best friend. I'm sure when the time comes, you will get members helping with their own pics.
Old Jan 30, 2008 | 09:27 PM
willyfastz's Avatar
willyfastz
Yeah I should have taken a few pics, what the heck was I thinking?
