500 hp from scratch
Old Jan 24, 2008 | 01:45 PM
sonomacrew01's Avatar
sonomacrew01
Default 500 hp from scratch
Thanks to Chris, Corvettekid, I've got a good foundation to start a 396 from scratch. After I get the 4-bolt block from him in May, I intend on bringing it to a good machine shop but I need to be fluent in "engine linguistics". What should properly be done to the block?
Going with forged 396 crank and pistons. Engine will be N/A so what style piston top should I look for?
What's a good cam/heads combination?
Old Jan 24, 2008 | 02:27 PM
rklessdriver's Avatar
rklessdriver
First it should be cleaned and magnafluxed.
If it checks out good there, then the oil galley should be deburred, and the oil returns opened up.
Then the mains should be line honed (at least checked for straitness), cyls bored and honed (w/a TQ plate preferabally).
Then it will have to be "Mock" assembled and the pan rail/bottom of the cyl "clearanced" for the rods and the deck height checked/block decked to set your piston to head/quench properly.
That covers the machine shop part of it.
As for the pistons - it depends on what heads you buy and what compression ratio you are shooting for. Really small combustion chambers are going to require dish pistons to keep the SCR under control. With bigger combustio chambers you could probally get away with flat tops which are easier on the wallet. I can't get too specific because without knowing 1) your SCR goals 2) your headgasket choice and desired piston to head clearance (quench) 3) actual cyl head specs its impossible to give you real specifics here.
500hp isn't that hard to make these days with a 396 inch motor. Personally I would recommend a set of AFR 210 elims and a camshaft in the mid 230's@.050 and .580-.600lift.
Will
Old Jan 24, 2008 | 04:45 PM
chucks88's Avatar
chucks88
Justin........didn't you just get your 383 dialed in
Old Jan 27, 2008 | 03:42 PM
sonomacrew01
Will
Thanks for the help on the block. I see I have to do a bit of searching. This engine will be a 1-2 year build and I want to do it correctly. Forgive me but what is SCR? Furthermore, will a machine shop/engine builder prefer to have everything so the block can be sized?
Chuck, still only have a 350 and yeah, mike at J&M is still working on it.
Old Jan 27, 2008 | 05:33 PM
rklessdriver
SCR - Static Compression Ratio.
Yes any machinest worth his salt is going to want the pistons you use in order to bore the block properly. Same with the rods and crank to clearance and set the deck height.
Will
Old Jan 27, 2008 | 05:51 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Go to JE/SRP's website and get there -14CC dish piston. It is an SRP piston, forged, but better for street than their JE psiton. Get regular tension rings, shave the heads for a 56-59CC chamber, after porting etc. Use a 52 or 58MM throttle body, 1 3/4 headers (Heated O2 sensors if 93 and older), Lunati 5.85 rods, Callies crank or Lunati 3.875 crank. Then you will need a camshaft from mid 230's to 240 in. dur at .050 and same for ex.
There, 500chp. (Almost like mine)
And tune it via who ever the heck you want, but at least get a good base tune, via PCMforless, my favorite, then dyno/real world data tune it further for fine tuning.
To 500 hp from scratch
