Outer Door seals
Old Mar 5, 2008 | 06:43 PM
FD2BLK's Avatar
FD2BLK
Default Outer Door seals
Just go my car back from paint and have completed all the new seals except the outer door seals. The kit I got did not come with the pop rivets, anyone know the correct size rivets for this? I would have just tried to go to the hardware store but the paint guy forgot to give me back my window controls so since I have to wait just wanted to see if anyone knew the proper size before I go. BTW the car looks amazing.
Thanks in advance
Old Mar 5, 2008 | 06:54 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Thanks in advance
Don't use pop rivets; use machine screws instead. This will allow you to remove or replace the seals with ease. Also, you will notice that there are no rivets or screws in the center of the door; only two on one end and one on the other end. This causes the center part of the seal to come off of the edge and pop up. You can remedy this by putting a very small bead of weatherstripping cement along the center of the seal before you apply it to the door edge. Use duck tape to fasten the seal in place while the cement dries. Don't worry if you get a little cement on your new paint as it can easily be removed with 3M Adhesive remover without harming the paint. This is all best done prior to reinstalling your interior door panels.
Old Mar 5, 2008 | 07:04 PM
Aardwolf's Avatar
Aardwolf
I used screws with my install. The correct rivet size is 3/16".
Old Mar 5, 2008 | 09:52 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Yes 3/16, and I like pop rivets.
Old Mar 5, 2008 | 09:58 PM
JackDidley's Avatar
JackDidley
Not much reason to remove these, once installed. If you do screws, use short ones. Too long will poke through the door
Old Mar 5, 2008 | 10:09 PM
FD2BLK's Avatar
FD2BLK
LOL and if you are not careful when drilling out the old pop rivets you can also drill a hole in the door, don't ask how I know I just do
Old Mar 5, 2008 | 11:57 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Who painted it?
Old Mar 6, 2008 | 04:53 PM
FD2BLK's Avatar
FD2BLK
Originally Posted by steve40th
Who painted it?
A friend of a friend who owns Stono Auto body
Old Mar 7, 2008 | 12:56 AM
steve40th's Avatar
steve40th
Hmm, I will be in Charleston within 3 years. I have always admired Jamisons work.
You got a link to picks on the forum?
To Outer Door seals
