From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Originally Posted by Pete K
Why pull the plugs? Disconnect the dist positive wire, and pull the fuel pump fuse. Then bump the key to spin the motor.
I want to see if any are damaged. Just verifying that nothing was dropped down there. I also perfer to turn the motor by hand, I will also pick up a compression guage and see how that looks.
I am 100% sure I did not SEE anything fall down the hole, I am NOT 100% certain nothing did.
Also, by hand I can check all the valve adjustments as I go. I may take the rockers and push rods out as I go to check them, then re adjust them.
This is a longshot but I think it's worth mentioning. I had a 92 and was on a trip cross country all of the sudden all hell broke loose clanking banging it was unbelieveable. Luckily I was close to a Chevy Dealership in Meridian, Miss. They fist thought it was a catostrophic failure from the way it sounded. They found a failed EGR valve dumped so much fuel into the exhaust that it cooked the pre-cats. All the ceramic ended up in the main cat and the metal that supported the ceramic was clanking and banging around inside the pre-cat housing and the noise resonated throughout the motor. Honest to God it sound like someone was hitting the block with a ball peen hammer.
It may be possible that with the new injectors and old pre-cats the same thing happened to you. Mine went from quiet to noisey quickly. I hope this helps.
Thanks, but the pre cats are gone, I have long tubes with brand new dual high flow cats.
Sorry I was hoping it would be something cheap. This is turning into one Hell of a mystery story . Good Luck Guy.
Like I said earlier, the only reason it's a mystery is I don't have time to spend 3 hours in a clip on it. I do some simple tests, post it, wait a week till I have some time, try again. That's what's dragging it out.
Incredulous!!! What kind of headers were you using. I want a set of those! When your headers scavenge so well that they out suck the the vacuum in the intake manifold, you've got some serious scavenging going on.
Gotcha. I thought you were removing them so you could spin the motor over.
RACE ON!!!
It was a 100% stock exhaust. You're way over my head or else I didn't explain myself clearly. I have no idea what your saying. The first thing the dealer asked is if my Check Engine light came on? It did not. Excessive fuel entered the exhaust the precats got cherry red and fell apart internally. I don't know what the intake manifold has to do with anything.
C4 of Year Winner (appearance mods) 2019
The EGR is in the intake. It's a device that lets exhaust back into the intake (to cool the burn). In other words, the sucking would be going the WRONG way for it to dump fuel into the exhaust.
Scavenging is a term used to describe the sucking effect that headers have on adjacent cylinders. It helps speed exhaust flow and, hopefully, intake flow (kind of like a mini super-charger).
It all adds up to a screwy diagnosis by that dealership. And CFI-EFI's comment was pretty funny!
I would back off all the valves a little so they are loose, and spin the pump again and see if they tighten up. Check for oil up at the rockers then. Sounds a little like the valve adjustment is too tight, repositioning the plungers in the lifters into a point that they can't get the oil up to the rockers, and can't function as hydraulic lifters.
thicker oil would also exacerbate the situation.
If I remember correctly, the galley plugs at the back of the engine are screwed in, and the front ones are plugs that are tapped in and staked unless the engine was rebuilt, and someone tapped the holes.
So this is when I get to work on the car, midnight.....
Anyway, here's a few pictures of the sparkplugs, not surprisingly they are a little black as I only started the car for five seconds at a time and it probably ran rich each time, but take a look see if you see something I'm missing.....
Some background....the balcker ones were on the passenger side.
I took the drivers side out before I did the injectors and they looked fine
None of the plugs are damaged, which, indicates nothing is in the cylinder, I hope.
Great suggestion. I will try that. Thanks. I'm going to re-adjust the valves. I suspect it could be something as you describe.
gp
That makes sense, the way they explained it to me was that it EGR stopped working and instead of recycling the unburnt gas back into the intake it went into the exhaust and burnt in the cat. I didn't give it a second thought after that.
I don't want to hyjack this thread so this is the last post here about my problem.
Things to do today:
1. Loosen all the valves
2. Change the oil to 10-30 (I think it won't make a bit of difference, but WTF)
3. Prime the pump with the rockers loose and see if they all pump up with the thinner oil
4. re adjust the valves after the priming
5. put the dist back in
6. new plugs
7. see if it starts
Comments?
While doing this I'll see if I can recognize a collapsed lifter.
Oh, and CFI, I'm picking up a stethoscope while I'm out. Thanks for the tip.
I was on the phone with a forum member. He said "don't sound good" at the end. I said I know it don't. That splains that.
Put the comp guage on each hole and get a reading on the squeeze. Pull the fire; you're not gonna' need to have it runnin' to find out which cylinder is havin' VALVE problems.
