codes?
The high resolution pulse from the opti can actually be measured with an oscilloscope if you tap into the right wire at the opti. Most people will not have the right equipment or know-how to pull this off and would not recommend it to most. However, loosing this pulse should not kill the engine. Pulse is used for timing advance and crank shaft position.
As far as the air temp code, you can check out sensor and wiring. Not a real common code. But ECM can be reading it wrong, or produce a code on its own.
No way to tell why car is cutting off going down road. But all these symptoms can be related back to a bad ECM.
A lot of this is opinion, not many hard facts to go on.
http://www.c4guru.com/articles/CCMCodePull.pdf
Code Description
13 Left Oxygen Sensor Open
14 Coolant Temp High
15 Coolant Temp Low
16 OptiSpark Low Resolution (Fuel)
21 TPS Signal Voltage High
22 TPS Signal Voltage Low
23 Intake Air Temp Low
24 Vehicle Speed Sensor
25 Intake Air Temp High
26 Quad Driver 1
27 Quad Driver 2
28 Quad Driver 3
32 EGR (Valve and/or Circuit)
33 MAP Voltage High (Low Vacuum)
34 MAP Voltage Low (High Vacuum)
36 OptiSpark High Resolution (Timing)
41 EST (Knock Sensor) Error
Code Description
42 EST (Knock Sensor) Grounded
43 EST (Knock Sensor) Circuit Error
44 Left Oxygen Sensor Lean
45 Left Oxygen Sensor Rich
51 MEM-CAL (ECM Chip) Error
52 Engine Oil Temp Sensor (Low Temp)
53 System Voltage Error
55 Fuel Lean Monitor
62 Engine Oil Temp Sensor (High Temp)
63 Right Oxygen Sensor Open
64 Right Oxygen Sensor Lean
65 Right Oxygen Sensor Rich
66 A/C Pressure Sensor Error
67 A/C Pressure Sensor or Clutch Error
68 A/C Relay Error
69 A/C Clutch Circuit
72 Gear Selector Switch Error
If you checked the pulses with an oscilloscope the only thing you can really see is that there are pulses there and their amplitude. It should be 5 volts.
I replaced my opti a while back. The rotor was dirty and the cap was corroded badly. I haven't checked the CCM yet but Datamaster is indicating a code 36 with the brand new opti. The books say if the counts aren't correct 5 times in a row it sets the code. This may be an indication that the counter circuits in the ECM are not functioning properly.
The Optispark is a very poor design but my car was running very good with the old dirty cap and rotor until I decided to wash the motor down a bit before reading the forum.
There is also a test connector between the ECM and the Opti, its under the fuel rail cover (Passenger side) you might clean this connector and the one at the opti itself.
Good luck.
