Driver's Side Window Is Loose
Old Apr 30, 2008 | 05:37 PM
Bad Karma's Avatar
Bad Karma
Default Driver's Side Window Is Loose
Anybody come across the same problem. window rolls up and down fine, but rattles and can be pulled up/pushed down in the rear of the window couple inches of total travel probably...
Any guesses on whats broken?
While it's apart any suggestions on replacing anything else? I figured I'd replace the bumper pads and window guide.
Old Apr 30, 2008 | 08:27 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Same with mine
Old May 1, 2008 | 04:29 PM
GlassToys's Avatar
GlassToys
Sounds like the guide stop is broken. Common problem.
Old May 1, 2008 | 10:17 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Or the studs/nuts from glass to rail, are loose.
Old May 1, 2008 | 11:24 PM
Redeasysport
Got a part #? I replaced the front stop I did not know there was a rear one.
Old May 1, 2008 | 11:26 PM
Redeasysport
I am getting an intermittant pop from the rear of the window when it is going down in the rear. It sounds metallic.
Old May 2, 2008 | 12:07 AM
KeyWestJack's Avatar
KeyWestJack
Old May 30, 2008 | 11:38 AM
Redeasysport
ttt
Old May 30, 2008 | 02:27 PM
corvettedan22's Avatar
corvettedan22
Take the door panel off. There is two tension brackets that keep tension on the window to keep it tight.
If not while in there you will figure it out.
Old May 30, 2008 | 06:41 PM
C4boy's Avatar
C4boy
That sounds like the rear guide needs to be adjusted.
Old May 30, 2008 | 09:31 PM
engle1147's Avatar
engle1147
remove the door skin & the aluminum plate...There is hardware in the very bottom of the door that hold the bottom of the bracket -- thighten the haredware down and then go for a spin over some small bumps and check for rattles.
To Driver's Side Window Is Loose
