85 fuel problems
Old May 28, 2008 | 07:37 PM
lincoln007's Avatar
lincoln007
8th Gear
Default 85 fuel problems
Have tried all the options as far as the obvious. No power to the fuse box for the fuel pump fuse listed in my manual as (EP). Any suggestions ?
Old May 29, 2008 | 08:19 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
There is a fuel pump relay on the firewall in the engine compartment.
Old May 29, 2008 | 10:03 AM
AGENT 86's Avatar
AGENT 86
When are you testing for voltage ??
Power is only there for 2 seconds unless your cranking or running.
Take 12 volts and insert the wire into terminal "G" on the ALDL connecter. That should send power to the fuse until the 12 volt wire is removed. Helpful when diagnosing.
My schematics are for 86 and not accurate enough for your 85.
Hopefully someone can post the 85 fuel delivery electrical schematic.
Old May 29, 2008 | 10:15 PM
lincoln007's Avatar
lincoln007
8th Gear
Thank you agent 86, the problem ws a bad fuel pump. However now the fuel gauge reads full which is not and the fan will not turn on so the car is over heating. Now what?
Old May 29, 2008 | 11:04 PM
jfb's Avatar
jfb
The main fan turns on at 228 F from temp measurement of the sensor that is on the front of the block under the MAF. Check the connectors on this sensor, they eventually degrade. Look at what the scanner says the coolant temp is compared to the dash coolant temp, they should be close. Ground the grn/wh wire on the fan relay with the ign on, this should close the fan relay and the fan motor should come on. Fan motors also don't last forever.
Old May 30, 2008 | 03:34 PM
YCarnut's Avatar
YCarnut
On the fuel gage problem, you might have left the fuel gage sender unit disconnected or the sender unit lost its ground connection. Both conditions will give you FULL indication on the gas gauge. The pink colored wire from the sender unit should be ~ 0 Ohm on empty and 90 Ohm with the tank full. With the pink wire from the sender grounded, the gas gauge should read EMPTY.
On the fan problem, I have attaced the cooling fan wiring diagram from my ’85 service manual. Hope it helps you, -good luck!
CHART C-12A, FAN CONTROL CIRCUIT
• The cooling fan is totally controlled by the ECM, based on
inputs from the coolant sensor and the A/C pressure fan switch.
The fan should run if coolant temperature is greater than 106°C.
• Battery voltage is supplied to the fan relay on terminal D
and ignition voltage to terminal C.
• Grounding CKT 335 (relay terminal B) will energize the
relay and supply battery voltage to the fan motor.
• The ECM will remove the ground to CKT 335 if vehicle
speed is over 35 mph.
• When A/C is used the fan control switch will open when
head pressure exceeds 233 psi (1600 kPa) and this input causes the
ECM to ground Circuit 335.
• If a Code 14 or 15 sets, the ECM will turn on the cooling
fan.
• The fan override switch is used for engine cooling if the
ECM fails.
To 85 fuel problems
