What Distributor Gear?
Old Jun 1, 2008 | 05:15 PM
dan_t's Avatar
dan_t
Default What Distributor Gear?
Hi all,
I've got a 1985 flat tappet block that I'm putting a Comp Cams 306 LT1 camshaft in, with retro lifters etc... What I want to know is what Distributor gear should I use for this cam? Will I even need to change it?
Comp cams don't list a gear for this cam as its for an LT1.
I'm running an F-body Distributor with external coil.
Old Jun 1, 2008 | 07:36 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Your going to need a melonized gear to work with the roller cam..
Old Jun 1, 2008 | 07:48 PM
AGENT 86's Avatar
AGENT 86
http://www.sdparts.com/product/10456...butorGear.aspx
Old Jun 2, 2008 | 02:39 PM
dan_t's Avatar
dan_t
Many thanks, have just orderd one
Old Jun 2, 2008 | 03:22 PM
AGENT 86's Avatar
AGENT 86
I hope you shopped around. I just posted that link as an example with part #.
Old Jun 2, 2008 | 06:08 PM
dan_t's Avatar
dan_t
I thought that looked cheap enough and when I checked shipping at only $7.95 to england I was very chuffed. Will bookmark that site for sure...
Thanks again...
Old Jun 27, 2008 | 05:08 AM
dan_t's Avatar
dan_t
this doesn't fit!
The I.D of the gear is bigger than the O.D of the Distributor was this for HEI only? I need one for a classic style, external coil distributor.
Old Jun 27, 2008 | 07:31 AM
bjankuski's Avatar
bjankuski
Originally Posted by dan_t
this doesn't fit!
The 1987 and latter F-body distributer has a smaller shaft and it is an external coil. I cannot garrantee that it will fit your distributer bacause I do not know what you have, but I believe the shaft size is .427.
Old Jun 27, 2008 | 08:04 AM
dan_t's Avatar
dan_t
any idea where I can find a Melonized gear for that distibutor? it is a 87-on distributor your right.
Old Jun 27, 2008 | 09:35 AM
bjankuski's Avatar
bjankuski
Look up a part number for a 1987 or later 5.7 TPI Camaro. You should be able to get one at the local GM dealer or at least the part #.
To What Distributor Gear?
