!!!HELP!!! Coolent leaking!!
Old Jun 3, 2008 | 10:45 PM
3Ran's Avatar
3Ran
4th Gear
Default !!!HELP!!! Coolent leaking!!
I have a 1988 Corvette. no real mods......air pump delete. trans:4/3. I started my corvette and drove it very hard......motor was cold( I know that was stupid!!). I got out of the car and saw coolent pouring/ driping down behind the front passenger tire. I still had to drive it home, and on the way home my lower right leg got covered in coolent. I think it might be the heater core. I im a newbe!! please help! battery also died a few days later. tryed to jump it , but no go. the car not starting might be the vats.............coolent could have done some thing....! should i replace heater core???
Old Jun 3, 2008 | 10:50 PM
schrade's Avatar
schrade
Originally Posted by 3Ran
I have a 1988 Corvette. no real mods......air pump delete. trans:4/3. I started my corvette and drove it very hard......motor was cold( I know that was stupid!!). I got out of the car and saw a coolent pouring/ driping down behind the front passenger tire. I still had to drive it home, and on the way home my lower right leg got covered in coolent. I think it might be the heater core. I im a newbe!! please help! battery also died a few days later. tryed to jump it , but no go. the car not starting might be the vats.............coolent could have done some thing....! should i replace heater core???
When removing and replacing hoses on the heater core, you have to be very careful to not break the core's hose nipple pipes.
Do not twist or pull core hoses. First thing to do is PUSH the hoses onto the nipple pipes. That expands the hose around the pipe, just enough to break the seal.
Old Jun 4, 2008 | 08:36 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If your leg got wet from coolant, there would have to be a significant leak at the core, since the core sits above the passengers feet.
To !!!HELP!!! Coolent leaking!!
