MERGED-(Fresh opti pull pics) & (Ignition stutter-Code crackers needed)
Old Aug 4, 2008 | 08:56 PM
  #141
blankmantn's Avatar
blankmantn
Hey guys.....I just bought this from Gordon Killebrew and am going to his house to pick it up tommorow. Maybe we all need one of these for future problems,,,, check it out..
http://www.gordonkillebrew.com/pages/800740/index.htm
I am going by there to pick up the 1982-93 ALDL Diagnostic Grounding Plugs & Manual for identifying fault codes. $45.00+$8.00 S/H for USA Zip Codes
Old Aug 5, 2008 | 01:09 AM
  #142
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
$45 dollars for a paper clip That is all it is and the info for IDing the codes is everywhere on the web (and FSM).
Old Aug 5, 2008 | 01:14 AM
  #143
blankmantn's Avatar
blankmantn
So this is not a good buy??
Old Aug 5, 2008 | 01:31 AM
  #144
schrade's Avatar
schrade
MMMmmmmmno.
You can pull codes on your '93 with a paper clip.
Try
http://www.oreillyauto.com/EW3/FindAStore.do
http://www.oreillyauto.com/EW3/HomePage.do
for your PCM. They quoted me $85 for the PCM (no core I don't think), before they found they couldn't get me one ('94).
Old Aug 5, 2008 | 01:38 AM
  #145
Redeasysport
http://www.corvettebuyers.com/c4vettes/codes.htm
Old Aug 5, 2008 | 09:44 AM
  #146
zeitgeist57's Avatar
zeitgeist57
Schrade? PCM yet? DAMMIT these shippers take a long time!
With the PCM possibly being the big problem, I'm glad Chevy mounted them on a bracket mounted so high up and easy to access that you could swap it out with your hands tied behind your back.
Spark plugs? Those are impossible to reach. Ahhh...but the PCM! That's a cinch...
Old Aug 5, 2008 | 01:38 PM
  #147
schrade's Avatar
schrade
It gets better than that...
Monday at 5:15 PM, I called CarQuest near here, told my guy there I'd pay max freight to get it 'next day', unless it had already left FLA.
It hadn't.
I don't get it. I just don't get it...
Old Aug 5, 2008 | 01:48 PM
  #148
schrade's Avatar
schrade
Tuesday 1:45 PM...
Called Blue Streak FLA to inquire order status. Phone lines are dow; can't transfer calls to status 'checker'.
Old Aug 5, 2008 | 01:52 PM
  #149
schrade's Avatar
schrade
Tuesday 1:50...
My CarQuest guy is at lunch.
I don't get it. I just do not get it...
Old Aug 5, 2008 | 02:23 PM
  #150
schrade's Avatar
schrade
Tues 2:17...
Called the dealer, and ordered a second PCM. Backorder, could be a couple of weeks. "Uh-huh; never hear THAT before..."
"No problem; get the order processed". $247; core additional.
Maybe one of 'em will beat Santa Claus to my house. Or the Easter groundhog...
I don't get it.
Old Aug 5, 2008 | 02:30 PM
  #151
schrade's Avatar
schrade
2:27 pm...
Car Quest guy just called back from lunch - "Blue Streak says my PCM is en route next day air".
Yeah. 'Course it is...
They open at 7:30 AM - should I grab my sleeping bag and toothbrush?
Old Aug 5, 2008 | 04:23 PM
  #152
schrade's Avatar
schrade
4:05 PM...
Blue Streak just called ME (they thought they had the wrong #)
My PCM is picked up supposedly.
Tracking Detail | Help Help
Billing information has been sent to UPS. Check site later for updated shipment status or contact shipper for more details.
Tracking Number: 1Z X33 355 01 4765 243 6
Type: Package
Status:
Billing Information Received
UPS has received the electronic transmission of shipment detail from the shipper and a label has been created for your shipment. Once UPS has possession of this shipment, the tracking status will be updated.
What should I do?
No action is required at this time. This is the most up-to-date information about the status of your shipment. Check Tracking periodically for shipment progress updates. If you don't see your shipment status change, you may choose to contact the sender to confirm that they have given the shipment to UPS.
Shipped/Billed On: 08/05/2008
Service: NEXT DAY AIR
Weight: 4.00 Lbs
Should I hold my breath? What's the definition of a 'DAY'? Because Venus goes around the sun faster than it turns on its own axis, which means a Venus DAY IS LONGER THAN A Venus YEAR!!!!!!!!!!!!!
Old Aug 6, 2008 | 04:02 PM
  #153
schrade's Avatar
schrade
Fixed!
Took a ride, reach traffic temps, no ignition faults.
All's left to do is confabricate some cooling figuration.
Old Aug 6, 2008 | 04:23 PM
  #154
zeitgeist57
Is it any smoother? You don't sound super excited. Granted, the process obviously was a bee-yotch.
Sooo...in the end how many PCM's do you have now? Can I get one for about tree fiddy?
Old Aug 6, 2008 | 04:35 PM
  #155
schrade's Avatar
schrade
It runs like a top. Got to 228, kicked in the fan, and never stumbled once.
It strung out the revs on the shift, like my old '87 did when I unplugged the TPS with it runnin', but after a few miles, it was shifting the way it's supposed to (just like the '87 did on that too).
Now, how do we set up cooling? Dryer ducting? Harness extension to interior? We can't go through this again.
The dealer and the CarQuest guys each have a standing order for another one. First one to come thru gets the cash - I told 'em both that...
Blue Streak yesterday told me they WOULD try to repair mine, but it would take some time - that's why they let go the one they had. I could get it back, which would be okay with me, cause I know they did this one right that I got now.
Old Aug 6, 2008 | 04:43 PM
  #156
zeitgeist57
Did'ja have to reprogram the PCM? Someone told me it needs to know your VIN#...is that something someone can do with a laptop, PCM cable, and OBDI software?
Old Aug 6, 2008 | 04:49 PM
  #157
zeitgeist57
Methanol injection. Or a spray of NAAAWWWS!
JEGS: "Are you running a boost configuration on that Vette of yours?"
ME: "No...just a high-dollar PCM replacement. Overheated the last one."
To MERGED-(Fresh opti pull pics) & (Ignition stutter-Code crackers needed)
Old Aug 6, 2008 | 04:56 PM
  #158
schrade's Avatar
schrade
They did it at Blue Streak with my VIN - plug n play. Cardon doesn't do it I don't think.
Give them a call; talk to Jackie or Hollie.
http://www.bsecorp.com/locations.php <--- #s there
I think you probably could do the flash yourself. It's in the chip; not the board. Right? My board looked like any pc motherboard - no cooked capacitors - nothing.
Makes me wonder if all I needed was a chip, and not a whole PCM.
ANYBODY???????????????
Old Aug 7, 2008 | 09:41 PM
  #159
schrade's Avatar
schrade
H72, H64, H41.
Old Aug 7, 2008 | 09:44 PM
  #160
schrade's Avatar
schrade
