Alternator AMPS
Old Aug 2, 2008 | 08:26 AM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
Default Alternator AMPS
I'm on my 3rd alternator in 4 years on my 90. The OEM was the first to go, then I replaced it with a reman'd from Advanced Auto and 2 months later, that one STB but they replaced it for me (they even installed it!). Well now I see that when I'm stopped at a light, headlights on, AC on and radio playing the alt gauge shows about 10, headlights dim and if turn signal is on the headlights sort of blink also. As soon as I give it some rpm's, the gauge moves up to around 12.
I am going to get it checked out today but can I replace the 105 amp with a 120 amp alternator without causing problems somewhere else later on?
Old Aug 2, 2008 | 08:32 AM
The Bus's Avatar
The Bus
If it will fit physicaly it will be fine. The alternator will only put out the current that the car/engine is using. For example ; if the alternator is capable of 105 amps and you are only requiring 40 that is what the alternator puts out. The reason the others fail they are too small and are always running close to or wide open. They overheat and fail.
Old Aug 2, 2008 | 07:00 PM
GKK's Avatar
GKK
I replied to your thread in the General section but, in general the CS130 alternators are hit and miss as far as rebuilts and a great upgrade is the CS144 120-140 amp alternators which use a larger case.
Old Aug 2, 2008 | 07:42 PM
jfb's Avatar
jfb
While your car isn't likely to require more current than the original alternator, if you install a higher current alternator, you didn't also install a larger output wire to the battery and a higher rated fusible link, which in theory could overheat (wire) or blow the fusible link.
Also, charge your battery up with a battery charger. Alternators aren't meant to charge up dead batteries, they get hot and this shortens their life.
Old Aug 2, 2008 | 10:57 PM
Southern Comfort's Avatar
Southern Comfort
I have the same problem, but I put a snap-on meter on the car and it showed that the volts on the dash were up to one full volt less than actual. That was crossed checked with another brand/type and it was the same.
I switched mine out to a Powermaster from Summit. I am comfortable with the alternator and my readout now.
Old Aug 2, 2008 | 10:59 PM
Road Agent's Avatar
Road Agent
Old Aug 2, 2008 | 11:36 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Switched to 140 powermaster/chrome, and no issues with amps, large sterio setup, light upgrades, etc... but i'd research and see if you have something shorting out the alt first.
Old Aug 3, 2008 | 01:08 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default alternator
The problem is the speed of the altenator.
The reason the volts increase when you give it gas is the pulley is too large on the alternator, causing it to drop off line at idle, and the battery voltage is what you see on the gauge. Auto electric shops can sell you a smaller pulley and install it as well.
A smaller pulley would allow the alternator to spin faster at idle, keeping up the amps and subsequently the volts.
Another way to get the alternator to put out more is to raise your idle by 500 RPM.
THis might bring the voltage producing speed up to where it is effective at idle. That's what I did. I couldn't find a smaller pulley here locally.
The reason rebuilt alternators fail is that cheap rebuilds use steel splices on the stator windings when they reassemble the alternator.
These overheat, and transfer the heat to the voltage regulator and destroy it from heat damage.
It is interesting to note as well that the voltage regulators have a thermister built in that drops the volts output by 1 volt when the alternator gets hot to keep from overheating the alternator further.
Old Aug 3, 2008 | 08:12 AM
larryfs's Avatar
larryfs
I've gone through 5 alternators from pep-boys. Then one day I was on the road, alternator failed again, found a mom-pop auto parts store who had a locally rebuilt unit on the shelf.
It's been in there ever since.
It's obviously the rebuilder, although I had pep boys "new" fail too.
Old Aug 3, 2008 | 03:43 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
A good quality unit, new, not rebuilt is what I bought. I has a lifetime warranty. Got mine for under $100 from Motor City.
Old Aug 4, 2008 | 01:02 AM
coupeguy2001
Default flickering dash
your dash flickers in the garage because the auto dash dimming circuit dims in small steps and it is discernable in a less than bright garage.
Old Aug 6, 2008 | 06:51 AM
Len90Vette's Avatar
Len90Vette
St. Jude Donor '10
JFB...where would I find this fusable link to check it? Not much of a mechanic but I do have good eyesight.
I checked all the connections on alternator and battery and all were tight.
Old Aug 6, 2008 | 06:58 AM
PAINTER MAN's Avatar
PAINTER MAN
I replace my alternator 60 days ago with a Napa rebuilt unit. Nobody can get a new one for my 86. Guess what, it went bad yesterday.
Old Aug 6, 2008 | 01:38 PM
BADDUCK's Avatar
BADDUCK
Motor City Reman has a 105 amp HD Maxx for your 1990 for $59,99. Go to there website and do a search. I have had mine 2 years, no problems. This is a straight bolt on.
Old May 28, 2009 | 12:01 AM
flash man's Avatar
flash man
Hello All,
This is an old post but I was researching alternator swaps. I have a black 86 Corvette that is eating up cs 130 alternators. I have two electric fans, ac etc. When at idle my volts drop down to 12. BTW. Do not purchase an alternator from a company on ebay called Rare Electric in Florida. I did and it lasted a month. They are wise guys and I got screwed. Anyway, I am upgrading to the CS144 alternator. The cs130's just cant handle the heat under the hood here in Florida. I can purchase a rebuilt from Advance auto for 140.00 lifetime warranty. I am also going to swap my 87 alternator too. I purchased a new cs130 for my 87 vette and it did last a few years. But now, the volts are dropping too. Its time to do both vettes. Take care.
Joe Flash man
Old May 28, 2009 | 07:58 AM
pcolt94's Avatar
pcolt94
I have never actually measured the output current from the alternator. I don’t know what is takes to run all the computers, ignition system, lights and wipers (excluding from moving seats, windows or momentary current draw). How much current is needed 99% of the time to run the car. This will give you an idea of what current capacity is really needed.
Say (i.e.) you pull 50 amps. A 100 amp alternator would be quite sufficient and a 130 amp would provide no real benefit. A higher current capability will not make it last longer unless you are close to max current rating. A good re-build or manufacturing will using quality methods and parts.
Got the car In 03, never changed the alternator and might be the original. It's hot in Orlando and doing OK so far (knock on wood).
Sounds like a nice weekend side project. I think the results will be interesting.
Old May 28, 2009 | 12:22 PM
jfb's Avatar
jfb
The fusible link is in the output wire from the alternator. They are usually close to where the alternator output wire gets connected to the battery. I am not familiar with the 90 vettes, but later C4's have a fuse block near the battery and it is possible that the fuse for the alternator is there. We need to hear from someone familiar with 90 vettes.
Old May 28, 2009 | 02:02 PM
SunCr's Avatar
SunCr
I quit counting at a dozen (at least 3 under the original warranty).
The last guy to put a Clampon on the output got 35 amps at idle.
Fans can draw 10 each, a worn blower motor can suck 20 to 25 on max.
Higher output doesn't always mean more at idle.
GM issued a Bulletin (in '96 or '98?) telling their Dealers to forget warranty reimbursement just because lights were dimming at idle.
Try www.alternatorparts.com for tutorials/more info.
The last guy who bought the "Iceberg" or dual rectifier alternator burned it up in 3 days.
To Alternator AMPS
