Opti-Spark Experts....Help needed
I checked for codes after that one time, but nothing set.
Have to see what happens I guess on the drive home this afternoon. Air temp will be around 100 and lots of stop-n-go traffic.
I checked the fuel pump output just in case....it has good pressure, holds pressure for several hours too.
It has got to be some electronic component that is getting HOT and causing this....I just do not know what it is.
OKAY; on the way home... lots of engine bucking, or cutting out...and then it finally died and would not start again.
Pulled the codes right then....Code 16: Low Resolution signal missing.
So has my new OptiSpark unit of 3 days gone bad? The engine started cutting out after only a few miles of driving last Sat and now it died. It did start back up after cooling down for about 45 minutes, long enough for me to get home.
NOW WHAT?????
You indicated in your original post the PCM was rebuilt. But what does that mean. Not like doing a engine or mechanical rebuild job. When generally testing or repairing electronics you are looking for failed parts but don’t generally replace parts that are working (unless suspect). If an intermittent problem existed with it, it might not have been discovered especially if it is heat related. If there is some sort of 5 volt regulation problem in the PCM, it could affect proper operation of the opti and dropout of the low resolution pulses. I’m just saying here in regard to all that information, it seems that the PCM could still be in the running as potential problem.
I wish I could pin point your problem or give some additional great suggestions, but finding this problem by shear testing is probably going to be tough since it quits on the road and you can’t carry you shop with you. I think you are on a good track by replacing some parts. I would never recommend to just throw parts at it but due to the nature of the symptoms, only time and driving will actual tell you when you are really fixed.
In the past I have wired LEDs into strategic parts of circuits to catch intermittent problems. This would take the place of a meter and gives immediate indications. Of course this requires higher level of electronics knowing how to wire it safety and what the indications mean as you configured them. This is just on one of my creative approaches but might give you some additional ideas.
How long did it run without cutting-out after OptiSpark replaced was less than an hour. Made three short trips: 8 miles then stop for 15 minutes, 7 miles then stopped for about an hour, 0.5 miles stop for gas, then headed for home, got about 500 feet from gas station and it bucked...got home fine. Total run time of about 30 minutes.
Last night was the first time it completely died for me. When it began to cut-out, I could just press the accelerator pedal and sort of "power" through it, but only worked for a few miles until it died and would not restart.
I tried wiggling the wire harness coming out of the OptiSpark, but still would not start.
As far as the "rebuilt" PCM...yeah right....have no idea if anything was replaced, got no information back with it. And since this is a heat releated issue, they may not have been able to duplicate the failure and just sent it back to me even though I paid $200.
I am going to borrow a PCM and try it, just to rule that out. Wonder if I should throw a new ignition module at it? Trying to troubleshoot an intermittent heat related problem is just not easy.
So my thought is to push a test wire into the OptiSpark harness and find the +5V supply and monitor this with the engine running and see if this drops out when the engine starts cutting out. If so, then it is the PCM which did not get fixed. Anyone have a wiring diargram of that 4 wire harness coming out of the OptiSpark?
with a borrowed PCM sitting on the passenger floor and tools to change out the PCM I drove to and from work.
Yesterday coming home, engine begins to cut-out, tach needle bouncing, comes and goes.
I get the car in the driveway and let it idle; cutting-out, revving up, comes and goes. Within five minutes it has died and will not restart. I quickly put a fuel pressure gauge on, just to be sure. Engine does start and run....fuel pressue is 40psig, begins to cut-out and revs up once again.
Shut it off, swapped in the other PCM...start engine, running smooth, let it run for five minutes....no problems at all.
So I think I have determined that the "rebuilt" PCM still has a heat releated problem that is not fixed.
Auto Computer Exchange is the place that "rebuilt" it....so much for their work. Going to be sending it back to them AGAIN...may be they can "fix" it this time.
