power windows..again
Old Sep 8, 2008 | 08:58 PM
joe wilson's Avatar
joe wilson
Default power windows..again
I have another power windows question; I removed the passenger side power window switch to test it for resistance. When I looked at it it wasn't what I thought it would look like. It has 5 terminals, so now I don't know which terminal is for what. Could anybody enlighten me on how to test it and what each terminal is for?
Old Sep 8, 2008 | 09:11 PM
engle1147's Avatar
engle1147
Been a long time since I messed with one of those....If I remember correctly those things are double pole double throw momentary switches...kinda tricky to ohm out.
I wouldn't worry about the switch just yet may be track down the wires/leads to the window motor and see if you can run that with some jumper wires to see if the motor or wires has an issue.
Old Sep 8, 2008 | 09:15 PM
engle1147's Avatar
engle1147
Formula 89 fixed his window by changing a light bulb....
Old Sep 9, 2008 | 12:59 AM
joe wilson's Avatar
joe wilson
I'm not sure the light bulb replacement was the fix; he may have just moved some wires around in his door enough to make contact. Anyway, I think all my lights are working.
Looks like I'm going to have to take the door apart. I remember what a hassle the other door was!!
Old Sep 9, 2008 | 03:07 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
For my '88 the switch wiring is:
-Pink==power from fuse block to Pin A
-Black==ground to Pins B & E
-Lt Blu==UP power to motor from Pin D (with ground to Pin C)
-Tan==DOWN power to motor from Pin C (with ground to Pin D)
Switch active position contunity is:
UP==A-D continuity; C-E continuity
DOWN==A-C continuity; D-E continuity
If you jumper Tan to ground and Lt Blu to +12Vdc the window should go up.
If you jumper Lt Blu to ground and Tan to +12Vdc the window should go down.
Old Sep 9, 2008 | 09:05 AM
formul89's Avatar
formul89
It seriously worked on my '94. I think the courtesy light bulb in the door panel completes the circuit for the window motor or the switch. I also removed the master switch, disassembled it and cleaned a lot of gunk off the terminals.
Old Sep 9, 2008 | 09:16 AM
MK 82's Avatar
MK 82
Originally Posted by formul89
I think the courtesy light bulb in the door panel completes the circuit for the window motor or the switch..
Beam Me Up Scotty!
YGTBSM!
Old Sep 9, 2008 | 09:20 AM
MK 82's Avatar
MK 82
From an 86 but it should be close.
Click Here!
Old Sep 9, 2008 | 09:22 AM
MK 82's Avatar
MK 82
What if you remove the light bulb?
Old Sep 9, 2008 | 09:29 AM
formul89's Avatar
formul89
Originally Posted by MK 82
Beam Me Up Scotty!
YGTBSM!
Look at your 94-96 FSM, genius.
Old Sep 9, 2008 | 09:41 AM
MK 82's Avatar
MK 82
Quiet! The adults are talking.
Old Sep 9, 2008 | 09:48 AM
formul89's Avatar
formul89
Exactly. Your childish comments add nothing here.
Old Sep 9, 2008 | 10:16 AM
car5car's Avatar
car5car
I believe that because GM engineers decided to run headlight circuit thru instrument cluster in 98 Saturn. That is really stupid!
Another stupid thing running right headlight door "close" wire thru relay and left one directly (w/o relay) on 84 Vette.
Here is another one for you: on some cars alternator circuit is going thru battery bulb in instrument cluster, so if bulb is dead alternator doesn't work!
Old Sep 9, 2008 | 10:25 AM
MK 82's Avatar
MK 82
Yes but the schematic would show that. Some folks couldn't read one if they had it!
Old Sep 9, 2008 | 10:42 AM
formul89's Avatar
formul89
Scan the schematic from your FSM for the door wiring on a 94-96 and post it here for us.
I want to make sure your manual is in English.
Old Sep 9, 2008 | 06:35 PM
engle1147's Avatar
engle1147
It seems as if I've disturbed a hornets' nest.... by mentioning the whole "fixed by a bulb" thing.
Old Sep 9, 2008 | 09:51 PM
formul89's Avatar
formul89
Nah, MK 82 has a superiority complex because he can read and has some bull sh*t degree.
I replaced the bulb and the window worked. I thought to myself "WTF?".
Oh well, one less thing to fix.
To power windows..again
Old Sep 9, 2008 | 10:31 PM
MK 82's Avatar
MK 82
So does that mean you have no degree and can't read. Somehow I think so. Sucks to be you.
Old Sep 9, 2008 | 10:38 PM
formul89's Avatar
formul89
Old Sep 9, 2008 | 11:26 PM
Lrod's Avatar
Lrod
I'm just gonna throw this out there so don't anybody bite my head off!!
I replaced the switch after Fu@king around with it for a few days. $20.00 on e bay.
