Major starting problem!!! Offering reward!!!
Offering money $$$ reward to person supplying winning solution to or testing procedure that leads to solution of my starting problem...I am having a hellacious starting issue with my 95. today I was driving down the road when all of the sudden I lost engine power. The engine seemed to have shut off. I imediately pulled over into a parking lot. When I stopped I noticed the car had an extremely aggresve Idle as if only one or two cylinders were firing. I turned the key off. I popped the hood and stepped out just in time to see smoke rising from under the hood. I though D*%$. Overheated... To my suprise the upper hose busted about in the middle. I pulled it walked to a parts store and replaced it. filled it with coolant and tried to start it... For some reason, it wouldnt start.
All kinds of things raced in my mind. Optispark, head gasket, etc. etc. I narrowed it down to what I considered spark or compresion. Rented a compression tester and all seems ok, unless I missed something. pulled the spark plugs, put them back in their boot and ran a wire from the plug to the block for grounding purposes. turned it over and no spark. I hosed down the optispark with wd40 to displace any coolant that might have got inside since coolant will not evap on its own. (gotta give it a little convincing) Let it dry, and did the spark test again, walla, spark. I put the plugs back in and turned it over again... no luck. But there is a change... It seems to kick back a little after I stop turning it over. And then if I keep trying it will eventually make a slight back fire sound out of the exhaust and then once in a while also out of the intake... I checked the plugs for water, oil or coolant, nothing found. I checked the oil cap and dip stick for water or whiting, nothing...
Im lost as to what to do next and am really looking to find a way to identify the absolute problem as I do not want to spend silly amounts to replace working parts... I am offering a reward to anyone who can bring me the solution or a testing procedure I can perform that will Identify to me the problem. I wont anounce the exact reward amount, but I will say it is in the tripple digits... Ill be checking both my email as well as this post regularly...
You have a 95 which has the MUCH improved vented opti. You would be quite surprised at what the vented ones can take.
"if the moisture coming in is greater than the little vacumme line can remove in time you will still fail the opti, or if the cap seal is old ad dry rotted then moisture is gonna slip right in at a seemingley uncontrolled rate and the little vaccume line will becore overwhelmed and overpowered"
Any amount of moisture is going to cause problems in the Opti, and it is not a matter of moisture ingress vs. vacuum rate........Yeesh...
...and you can buy deep inverse Torx set from Harbor Freight Tools to open up the Opti.
Also, I find it a bit insulting to offer $$$$ reward for whoever comes up with the solution. That's not what this forum is all about....
Please use Paypal to submit $1,000 Euro's into my Ebay account.
USD not accepted until our financial system has regained solvency.
The engineer that designed them should be shot..A fly could **** on them and it will create all kinds of problems
..Check it out for cross fire...Good luck..You'll get it
