head pounding Drone
Old Sep 24, 2008 | 02:14 PM
alanterhk2's Avatar
alanterhk2
Default head pounding Drone
I need Help!! I have a 88 with a 383 and modified TPI to auto trans.I have Headmen headers that fead 3" pipe to a dual inlet cat to single 3" that goes to 2.25 split to two muffs.That is a mouth full.I have a reonating or drone at 1800-2300rpm that give a headache.If under WOT it is ok.I have had a turbo muffler set up and flowmaster set up with nearly the same result.Turbos were betterbut not great.My question is , are there any muffler that dont produce this drone or could I use a factory muffler without much loss.I drive this everyday and I cant afford Excedrin anylonger as gas is crazy! Help would be appreciated!!!
Old Sep 24, 2008 | 02:26 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
You can go to a factory style muffler and it will help. Corsa's should also help but they are expensive. The headers with a single cat cause a lot of the problem.
Old Sep 24, 2008 | 03:22 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Corsa
Old Sep 24, 2008 | 03:47 PM
cv67's Avatar
cv67
St. Jude Donor '05
Spend the money once....I cannot believe how quiet they are inside.
Just about anything outside of stock will have some drone except these.
Old Sep 24, 2008 | 05:33 PM
skybolt31's Avatar
skybolt31
I think the ones I had on my 86 were Dynomax, but I blocked one of the four outlets and it made a big difference. Didn't eliminate it but it was much better.
Old Sep 24, 2008 | 06:18 PM
F1Fan's Avatar
F1Fan
I've had it with my loud, leaky, droning pos exhaust too. The drive home today finally pushed me off the fence to bite the bullet and do something about it.
Old Sep 24, 2008 | 07:44 PM
USAsOnlyWay's Avatar
USAsOnlyWay
This happens with the Magnaflow catbacks. LD85 found that stuffing the inner pipes of each muffler with steel wool helped with the resonance and lowered the decibels.
I've also heard of people with X-pipes having less problems. You'd have to redo your center exhaust section.
Old Sep 24, 2008 | 10:06 PM
etteroc27's Avatar
etteroc27
I put Flowmaster Force II's on my 95, with shorty headers. NO drone, and great sound under acceleration.
Old Sep 24, 2008 | 11:46 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Turbo and Flowmaster's have similar sound-deadening properties (i.e., not much).
On mine, I found that adding Magnaflow front cats made all the difference. I had loud side-pipes after the main cat, so I bet straight pipes after the center cat would still sound great on yours! A bonus would be the ability to pass a visual -- if ever needed.
If possible, make sure tail pipe extends a little past bumper. NOT TOO much though! Otherwise, you a busta you shin!
gp
Old Sep 24, 2008 | 11:49 PM
GREGGPENN's Avatar
GREGGPENN
Something about LTx cars has always sounded quieter to me....
Old Sep 25, 2008 | 04:57 AM
85 500 horse's Avatar
85 500 horse
B&B isn't any better. I may need to go to a Corsa setup if I can't get the drone under control. They're about the only ones out there that will do what you're looking for.
Old Sep 25, 2008 | 07:10 AM
alanterhk2's Avatar
alanterhk2
Thanks all, sounds like I am not the only one keeping Excedrin in business! Will try to cats and new muffs.AI already have a crossover so I should be ok on balance!
Old Sep 25, 2008 | 08:20 AM
kenmohr's Avatar
kenmohr
Put Corsa from Jegs on my 89. Very nice and almost no drone. Have had many comments on them. All good.
Old Sep 25, 2008 | 09:29 AM
jimmymack's Avatar
jimmymack
St. Jude Donor '09 thru '25
Originally Posted by AGENT 86
Corsa
No resonance, great sound. Sometimes ya just gotta spend the money. If you are keeping the car, the payback in satisfaction on having a car that doesn't drone is worth every cent.
Old Sep 25, 2008 | 10:00 AM
mdlfcrss's Avatar
mdlfcrss
Same here, I took off Flowmasters and went for the Corsa System. Best money I've spent on the car to date. You won't be sorry with Corsa's. (until you have to pay for it, that is)
To head pounding Drone
