My VATS experience
Old Oct 16, 2008 | 02:47 PM
alecracing's Avatar
alecracing
Default My VATS experience
It's weird how all the VATS posts on here involve the Wire going from the key cylinder, yet, the 2 instances I have had with it turned out to be the module. The module was seeing the key and activating the starter enable relay but no injector pulse. I found the module was not sending the signal to the ECM to pulse the injectors.
I bought a bypass module for my 'vette but one of my students has an '89 Camaro with the same problem.
I don't remember where I got the bypass module, anyone know.
Old Oct 16, 2008 | 03:16 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://www.ecklers.com/search.asp?ac...searchHistory=
Old Oct 16, 2008 | 03:21 PM
alecracing's Avatar
alecracing
thanks but my VATS module is recognizing the key, it is just not producing a signal to go to the ECM to start pulsing injectors.
none of the fixes for the broken wire in steering column will work
Old Oct 16, 2008 | 03:26 PM
jfb's Avatar
jfb
A very high percent of stolen vehicles are done by bashing the column and jumping the ignition. YOU are now a candidate! Good luck! I prefer to repair my VATS and keep my Corvette. I bought my 87 from someone that ordered a 90 and shortly after taking delivery, they came out of work to find the drivers window broken out, the steering column busted open, but the 90 vette hadn't moved an inch.
If your left headlight quits, are you going to epoxy a flashlight onto your hood?
Keep your car in good repair!
Old Oct 16, 2008 | 03:32 PM
3D-Aircrew's Avatar
3D-Aircrew
Default Very interesting!
I have an intermittent no start condition that has left me stranded before yet the engine has always cranked so I assumed it must not be VATS.
However it did not have spark. Does the VATS module give a signal to the ECM for spark as well?
Old Oct 16, 2008 | 03:53 PM
3D-Aircrew's Avatar
3D-Aircrew
Default thepartsladi had VATS modules
http://cgi.ebay.com/ebaymotors/86-87...mZ390001413871
Thepartsladi has the modules
Old Oct 16, 2008 | 07:22 PM
AGENT 86's Avatar
AGENT 86
Sorry, I quickly read your post and it sounded like you were looking for a bypass for a student's car.
Old Oct 17, 2008 | 12:09 AM
jfb's Avatar
jfb
VATS closes the start enable relay and sends a square wave to the ECM to allow injector pulses. VATS does not control spark. You need to look at the spark coil, spark module, and the pickup coil, all of which must work to get spark.
Old Oct 17, 2008 | 12:19 AM
gw962's Avatar
gw962
I think that FieroAddiction.com has a module that plugs into the ECM and bypasses the VATS unit. They sell it mainly for conversions to TPI/ECM .
Old Oct 17, 2008 | 08:31 AM
anesthes's Avatar
anesthes
I have 21k insurance on my car. I'd rather wake up to find it GONE than a broken window, column..
-- Joe
Old Oct 17, 2008 | 10:15 AM
redrose's Avatar
redrose
VATS sends a square wave to the ECM to allow injector pulses.
VATS does NOT send a signal, it "sinks" (grounds) an output voltage of 5v from the ecm at 30 hz.
build or buy a 30 hz VATS simulator, bypass the starter enable relay, no more problem ever...add a hidden "kill" switch if you are part of a high-crime scene.
a VATS simulator is not just a resistor.
Old Oct 17, 2008 | 10:21 AM
redrose's Avatar
redrose
VATS does not control spark...your problem is most likely a sick "ignition module" in the distributor, if "no starts" are occuring more often with a hot engine, the igniyion module is very highly suspect.
Old Oct 17, 2008 | 10:34 AM
jfb's Avatar
jfb
Pulsing a 30 Hz signal from a 5v source is sending a signal to the ECM. Also, you still can have a no crank if the clutch safety switch fails, gear selector switch if automatic.
Old Oct 17, 2008 | 10:42 AM
MK 82's Avatar
MK 82
You can have vats totally programmed out.
Old Oct 17, 2008 | 10:53 AM
jfb's Avatar
jfb
And why would you want to do that? It just makes it easy for car thieves to take your Corvette!
Old Oct 17, 2008 | 10:55 AM
anesthes's Avatar
anesthes
It's a vette, not a honda civic. Nobody wants 'em.
-- Joe
Old Oct 17, 2008 | 02:02 PM
redrose's Avatar
redrose
Pulsing a 30 Hz signal from a 5v source is sending a signal to the ECM. .
those not "challenged" in electronics may desire to build their own VATS sim...takes under $10 of raddyshack parts...if an external 5v source is pulsed and sent TO the ecm, at best the ecm will do nothing...the 5v output FROM the ecm must be treated to a 30hz sink for the ecm to fire the injectors...sorry if this was not explained clearly.
btw, late c4's need a 50hz sink (94+ IIRC).
To My VATS experience
Old Oct 17, 2008 | 03:44 PM
MK 82's Avatar
MK 82
Because theives expect it to have vats and steal an easier car. The stupid ones will bust your window regardless.
If you are that paranoid, install a hidden kill switch.
Old Oct 17, 2008 | 03:58 PM
alecracing's Avatar
alecracing
Thanks, I'll keep an eye on it.
Not the LEFT headlight, but maybe the right
Yes, i was looking for a bypass, but all the one's that I have found just tell the VATS module the the key is correct. I am looking for a bypass that "sinks" the proper frequency signal from the processor.
exactly, my VATS module IS closing the starter relay, but not sending/sinking the injector pulse signal
HOW?????
-- Joe
Old Oct 17, 2008 | 04:03 PM
alecracing's Avatar
alecracing
so it is possible that the processor is not sending the signal, can I check this with a DVOM?
If I have the module plugged in and try and start the car, I should see ground on the dark blue wire, correct.
And I should also see a 30Hz signal from processor,right?
I remember when I bought mine the company told me that there were 2 different modules. One was 30Hz and the other 50Hz
