87 trouble code 36 is?
Old Oct 19, 2008 | 10:48 PM
player.w's Avatar
player.w
4th Gear
Default 87 trouble code 36 is?
I have the paperclip to get code 36 but i dont have a book to figure out which part to change.thank you so much. I hope all your vettes are running great!
Old Oct 20, 2008 | 10:04 AM
todd_vette's Avatar
todd_vette
Code 36 is the MAF burn-off relay circuit. Ckeck all the connections very closely and if that doesn't show a poor conection then it is ussualy the relay it-self mounted behind the battery. There are 2 relays there so the trick is figguring out which is bad.
Old Oct 20, 2008 | 11:12 AM
rick lambert's Avatar
rick lambert
Everthing I've read, including FSM says to replace both relays, MAF burnoff and power relay at the same time...not just one.
Old Oct 20, 2008 | 03:21 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/corvette86/Code%2036.pdf
Old Oct 20, 2008 | 10:15 PM
newbecorvetteguy's Avatar
newbecorvetteguy
No trick. They're $9 each at NAPA and the ones in the car are 22 years old. Change them both and forget about it.
Old Oct 20, 2008 | 10:55 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default newbie
We have a wise Newbie that has joined the ranks
Old Oct 22, 2008 | 01:50 AM
espop125's Avatar
espop125
worst case get them from mid america my 86 was throwing multiple codes all related to mass air flow sensor so I bought both relays for &20.00 at mid america and problem fixed. Takes about 5 minutes to change them.
Old Oct 22, 2008 | 10:25 AM
rick lambert
And after you replace them you'll want to disconnect the battery for a few minutes to clear the code.
Old Oct 22, 2008 | 06:21 PM
todd_vette's Avatar
todd_vette
ACATCHA 22!
Get jumped if say to over replace items. Get jumped if you say not to.
And no-one noticed that i purposely left out saying to replacing any.
So is this ACATCHA33? (or23?)
Yeah, replace both...if one went then chances are the other is soon to follow. My bet would be that the FSM uses that theory to reduce the likely hood of returns...it is cheeper than shop hours, and reduces customer complaints. Only guessing though.
You should probably clear the code and see if it returns before replacing any. If it doesn't then you are done. If it waits a few trips then comes back it is more likely a connection or bad wire problem. It NORMALY will reset on second start after clearing if a relay is bad.
To 87 trouble code 36 is?
