Another headlight thread...
Old Nov 13, 2008 | 10:19 AM
Jimbo3087's Avatar
Jimbo3087
Default Another headlight thread...
So I thought I had fixed my headlight motors.. I figured out that the relays were bad.. They worked for about a week, and started to stop working again. So I bought some new relays and put them back in and they worked for about a week. So instead of blowing $45 a week I decided I need to try and find out what the hell is going on.. Any ideas?
Old Nov 13, 2008 | 10:23 AM
runner140*'s Avatar
runner140*
Jim, what are they doing or not doing that you need to fix?
Old Nov 13, 2008 | 10:42 AM
Jimbo3087's Avatar
Jimbo3087
Sorry, just getting the doors to open and close.. The doors always close but don't always open.. When I first change the relays the doors work fine for about a week.. But the right headlight is usually the first to go. Then eventually they both stop opening.
Old Nov 13, 2008 | 11:54 AM
rick lambert's Avatar
rick lambert
Are you sure it's not the bushings? One of my headlights wouldn't come up after a paint job, the cover was just barely hitting, just needed a little adjustment. I hope you cleaned all the relay connections. You may even want to pull the connection and inspect the back side, look at the wires.
Old Nov 13, 2008 | 03:56 PM
Jimbo3087's Avatar
Jimbo3087
I'm pretty sure its not the bushings.. Because as soon as I put a fresh set of relays in the doors work fine..
Old Nov 13, 2008 | 04:39 PM
GKK's Avatar
GKK
Sounds like the headlight motors need to be replaced. Too, much electrical resistance causing the relays to fail.
I had the same problem and after many checks and testing, I finally decided to buy two replacement motor assemblys from Ecklers which solved the problem.
To Another headlight thread...
