intermittant hard start
Old Dec 8, 2008 | 09:38 PM
ghostflames's Avatar
ghostflames
4th Gear
Default intermittant hard start
Looking for some help. I have a 88 C4 TPI L98. It wants to crank a long time on occasion before it starts and runs rough for a few minutes. Once its running it runs great. Does it when cold and also when hot. But seems to act up most when parked on a incline. I had it at the dealer and they could not get it to do it. Any help or sugestions would be appreciated.
Old Dec 8, 2008 | 10:28 PM
engle1147's Avatar
engle1147
Got any stored ECM codes?
A great place to start is by check your fuel pressure at the fuel rail with the engine running...then turn the engine "off" and see how long it takes for the fuel pressure to drop. I'd tell you to do a search for "fuel pressure test"....but I understand the forum "search" function has been experiencing technical difficulties over the last few days.
Welcome to the forum!
Old Dec 9, 2008 | 09:16 PM
ghostflames
4th Gear
Thanks will check fuel rail pressure. Also forgot to mention it displays low coolant temp on drivers display when I start it up. Even on a hot day. Would coolant temp sensor cause the starting problem? Or is that normal until engine reaches normal temp? Thnaks again for your input.
Old Dec 9, 2008 | 10:59 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The coolant temp sender is in the passenger side head. Check to see if the connector is clean and tight, or even hooked up.
Here is some info to help diagnose you hard starts. Read it and I'll quiz you tomorrow.
http://members.shaw.ca/corvette86/6E3-B%20Symptoms.pdf
http://members.shaw.ca/corvette86/Fu...mDiagnosis.pdf
http://members.shaw.ca/corvette86/Co...rt%20Valve.pdf
http://members.shaw.ca/corvette86/Co...0View%2086.pdf
Old Dec 10, 2008 | 08:00 AM
WW7's Avatar
WW7
When the car is first started it should read (LO) until the engine reaches 100 degrees, then it will work from there up. This is suppose to be done so the higher temps are more accurate, at least thats what GM says...WW
Old Dec 10, 2008 | 01:08 PM
Jims1988C4's Avatar
Jims1988C4
I had the EXACT same problem with my 88. I replaced my injectors,(thanks jon),ran much better but same starting issue,then I replaced both MAF burn off relays and my ECM, She has never run better and always starts no matter what.
Old Dec 11, 2008 | 02:09 AM
onefinecar's Avatar
onefinecar
I had hard starting problem with my 88 and after researching the forums, I replaced both MAF relays ($30) and cleaned the throttle body plates with TB spray ($6). Also inspected all wiring for any loose or sloppy connections and problem went away. Possible you have a leaking injector or two if they are original and have not been touched in 20 years. Hope this helps.
Old Dec 11, 2008 | 11:37 AM
ghostflames
4th Gear
Great forum. Thanks for all the helpful info. I can not get out into the garage till next week to do some troubleshooting. But I will post back with what I find. Thanks again for everyones help and input.
Old Jan 2, 2009 | 10:30 AM
ghostflames
4th Gear
Think I may have solved problem. At least it seems like it so far. I checked fuel pressure. And all checked out good. I also tested all my injectors and they tested good. I bought a can of MAF cleaner and cleaned MAF sensor. Seemed good for about a week and problem came back. I then changes MAF relay and has been good so far. So am crossing my fingers. That I solved problem. Even though injectors tested good. I am planning on buying a set from FIC. Since car has 115k on the odometer. I also changed all the burnt out bulbs in my dash cluster. After reading a how to post in the forum. All I can say this is a great forum with a wealth of info. Thanks again for everyones help!
Old Jan 2, 2009 | 05:28 PM
bczee's Avatar
bczee
I have some of the hard starting problems on my 88 also... if it comes back, try the flooded mode start (hold the pedal to the floor and try starting it..) that usually works for me.. but most likely will order a set of injectors from FIC by months end..
To intermittant hard start
