Sensor wiring question please help
Old Jan 4, 2009 | 09:30 PM
buddylee432's Avatar
buddylee432
Default Sensor wiring question please help
Ok the senosr that is attached to the underside of the plenum kindof in front of the distibutor that jhangs upside down... I cant locate the wire connector that plugs into the sensor. Where do I look for it now that it is not obviously visible to me? This may be why my MAf sensor is not working correctly I dont know. Someone please help me out here.
Old Jan 4, 2009 | 09:33 PM
eguyett1985's Avatar
eguyett1985
That's the IAT sensor and that 2-wire harness runs on the RH side of the distributor (right by the distributor clamp bolt) and has a 2-way Weatherpak connector coming off the main ECU harness right there at the back of the engine...sorry I don't have a photo handy.
Old Jan 4, 2009 | 09:36 PM
buddylee432
I have seen two male plugs that are in that location and one looks like it may plug into it but it wont reach over to the sensor....These two plugs are just laying out on top of the passenger side valve cover becuase I dont know where they go. Is there some type of extension maybe?
Old Jan 4, 2009 | 09:51 PM
eguyett1985
Yes, the harness will have the mate to the ECU end of the harness (regular 2-way WP) on one end and the male plug that will mate with the IAT sensor on the other end (going from memory it's like 8-10" long). If you're missing that harness you could make another one using the correct connectors, seals, and pins. The other connector you are seeing in that area no doubt is the EGR solenoid connector which is a different style of Weatherpak (not the regular 2-way) it's similar to the two used up front on the diverter valve solenoids.
Old Jan 4, 2009 | 09:57 PM
engle1147's Avatar
engle1147
Thought the inverted impossible to connect plenum sensor was the MAT....snap a pic of the ? connectors and post it.
Old Jan 4, 2009 | 09:58 PM
eguyett1985
IAT=Inlet Air Temp
MAT=Manifold Air Temp?
Same thing
Old Jan 4, 2009 | 10:14 PM
buddylee432
So it actaully has a removable link (wiring harness) that may not have been put back on? I purchased the harness off of ebay so I will see if that will work. Maybe one of the two plugs that are not hook up are the IAt sensor plug. I did take pics and put them in my computer pics but cant figure out how to post them...How do you do this? Or can I email them to you?
Old Jan 4, 2009 | 10:16 PM
engle1147's Avatar
engle1147
Originally Posted by eguyett1985
IAT=Inlet Air Temp
Same thing
I guess you got me on that one.......as long as we're on the same page.
Old Jan 4, 2009 | 10:18 PM
engle1147's Avatar
engle1147
You can email me and I'll post them if you want....I'll shoot you a PM with my address.
Old Jan 4, 2009 | 10:19 PM
eguyett1985
Yep, the IAT harness plugs in at both ends. On the pics you'll have to post them up here or email them.
Old Jan 4, 2009 | 10:20 PM
eguyett1985
I figured we were probably both thinking of the same thing!
Old Jan 4, 2009 | 10:35 PM
engle1147's Avatar
engle1147
I never got your email....you want to try to send it again?
Old Jan 4, 2009 | 11:07 PM
engle1147's Avatar
engle1147
Old Jan 4, 2009 | 11:14 PM
eguyett1985
Ok, the plug in photo #3 is the IAT harness plug. The plug in photo #4 will go to the EGR solenoid. Teamwork...I like that!
buddylee432
I am thinking that pictures 2 and 3 are the one for the iat sensor. What about yall?
Old Jan 4, 2009 | 11:17 PM
buddylee432
lol egr solenoid...thats another problem...I dont have anything but a single wire coming from the egr valve. The guy said he didnt hook up the egr valve when he deleted the air pump system. What would you do? The valve itself is still there but no electrical plugs for the pictured plug. Do I absolutely need the egr hooked up
Old Jan 4, 2009 | 11:21 PM
engle1147's Avatar
engle1147
no but it will need to be blocked off if it is not already.
What are the wire colors you have on these connectors include the tracer color if it has one?
To Sensor wiring question please help
Old Jan 4, 2009 | 11:22 PM
buddylee432
Ok I looked at what a egr solenoid looks like and I dont have the solenoid..Can I run without it or do I need to buy one.
Old Jan 4, 2009 | 11:24 PM
buddylee432
Well the egr valve is on the intake so how do you block it off. Does the egr valve produce vacumm out of the little neck that comes out of the side? can I just leave it on and plug that neck? Do I need to unplug that single wire connector?
Old Jan 5, 2009 | 06:31 AM
buddylee432
Could it be that the car runs better without the mass air flow sensor becuase the iat isnt hooked up?
