Miniram Reduce TQ?
Old Jan 22, 2009 | 12:41 PM
pologreen1's Avatar
pologreen1
I don't have one, but it sounds like maybe on the numbers side of things a little at low revs, but maybe the hp takes care of it later, because people love them, and they sure can rip from a hole, from what I have seen
Old Jan 22, 2009 | 01:41 PM
LD85's Avatar
LD85
Originally Posted by Pwnage1337
How much modification does HSR require to fit under the hood of a C4?
http://forums.corvetteforum.com/c4-t...ification.html
Old Jan 22, 2009 | 01:43 PM
LD85's Avatar
LD85
Originally Posted by anesthes
I think the problem with a singleplane for N/A use is the throttle body and air cleaner. I'm not sure you'll benefit from sucking in hot air over the engine, and by running a 90* elbow and plumbing you're defeating the purpose of directly filled cylinders. A hood scoop would be best but that would kinda take the whole street car image away.
-- Joe
406ci
Single Plane
11:1
TPIS 701 cam
TKO 600
122mph in 1/4 on street tires.
Old Jan 22, 2009 | 02:05 PM
Pwnage1337's Avatar
Pwnage1337
which intake do you think will provide the best overall gains, the BBK, Miniram, or HSR?
Old Jan 22, 2009 | 02:17 PM
LD85's Avatar
LD85
Key word being "overall"..............
IMHO the HSR
Old Jan 22, 2009 | 03:44 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
The plenum is about 1" too tall. You either need to:
1) Cut, weld, shorten the plenum
2) Make a whole new plenum
3) Get a hi-rise hood
4) Buy the USM modified version (link here.)
There are a couple of posters who've modified one -- if you do a search. (You could start with LD85 above). :-)
Old Jan 22, 2009 | 06:23 PM
mseven's Avatar
mseven
Originally Posted by LD85
406ci
Single Plane11:1 TPIS 701 camTKO 600 122mph in 1/4 on street tires.
LD, is this your current set-up?
here we go...lol
Old Jan 22, 2009 | 07:09 PM
LD85's Avatar
LD85
Originally Posted by mseven
LD, is this your current set up?
No, this is ol'Rjs setup
