Starting Problem
Old Jan 27, 2009 | 12:13 AM
gofltn's Avatar
gofltn
8th Gear
Default Starting Problem
I posted this in someone eless thread so I'm going to make one for myself. I just finished replacing the stereo and speakers in my 1988. I started with removing all four bose speakers and replacing first the rear speakers and the head unit. Everything worked fine and for a few days while I drove it around with just the rear speakers. Yesterday I removed the door panels as well as the top of the dash to see which would be easier to install speakers into. I decided to just work with the the ones in the door panels. I attached new speakers to the old bose wiring. After testing that the speakers worked I replaced the panels and sealed everything up. At this point I tried starting the car and it was a no go. The stereo and everything turns on but there is a loud clicking sound. when opening the doors I found that with just the passenger door open the security light comes on but the opposite for the driver side. Prior to the installation I haven't had any other problems with the vehicle starting. As the problem seemed to come from the driver side I removed everything once again including the connection to the speaker tried staring but with the same result. I then proceeded to reattach all the wiring except for the speaker and ended withe the same result. If any one has any words of advice it would be much appreciated I am new to working on cars and this was a big hit to my motivation but am determined to not let it stop me. Thanks in advance to anyone that has any input.
Someone has already suggested jumping it as I might have drained the battery during the installation, I will try that later tomorrow along with any other suggestions. Thanks in advance.
Old Jan 27, 2009 | 12:53 AM
rodj's Avatar
rodj
"there is a loud clicking sound."
From dash or engine bay?
Are the wires connected to the door locks?
That is part of the security system
Old Jan 27, 2009 | 01:06 AM
gofltn's Avatar
gofltn
8th Gear
It's coming from the engine bay. I reconnected all the wiring harnesses that I took off so the door locks should be wired back up.
Old Jan 27, 2009 | 01:52 AM
rodj's Avatar
rodj
Originally Posted by gofltn
It's coming from the engine bay. .
That means all is well because you have power to the starter solenoid if it is clicking.
You have flat battery or bad starter solenoid contacts.
Old Jan 27, 2009 | 08:32 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If you were working in the cabin with the battery hooked up, chances are your courtesy lights ate up most of your battery power.
Also, check for clean/tight battery connections.
Old Jan 27, 2009 | 11:09 AM
gofltn's Avatar
gofltn
8th Gear
I will check all of this today after I'm done with classes thanks for all of the information.
Old Jan 27, 2009 | 04:37 PM
gofltn's Avatar
gofltn
8th Gear
The vehicle is still not starting. I reconnected all the harnesses back to the doors checked that the power locks worked attached the jumper to the battery and when I went to start this time only one click and everything goes dead. I took the starter off undid the negative from the battery for about ten minutes. When I replaced the connection all the lights turned back on and the battery reads 10.9 volts. I attempted to start it up again and just the single click and then everything goes dead. For both of these attempts I used my spare key and not the normal key. Does any one have any more suggestions?
Old Jan 27, 2009 | 05:53 PM
josephf31's Avatar
josephf31
Default That's
pretty low battery voltage. Have you tried jumping it from another running vehicle? Otherwise sounds like could be a short which is a royal PITA to trace...
Old Jan 27, 2009 | 07:54 PM
engle1147's Avatar
engle1147
Before you go tearing into stuff...remove the battery and have it load tested at an auto parts store...most stores will test it for free.
Old Jan 27, 2009 | 08:29 PM
gofltn's Avatar
gofltn
8th Gear
ok so hit the battery with a multimeter it was reading 12 volts. So cleaned off the negative connector a little and then rolled the it back about a foot in neutral. I Connected it to a jumper just in-case and started right up. Thanks for all the input every one. My next step is to put an amp in it. It's a slow process with time and money constraints but I love working on it and I'm learning so much more about the car as I go. Thanks once again for the help the last few days i was a little worried.
Old Jan 28, 2009 | 12:10 PM
josephf31's Avatar
josephf31
If it started when jumped I'd say it's a bad battery, if it's more than a few years old I'd replace it anyway.
To Starting Problem
