Power steering problem
Old Feb 15, 2009 | 02:29 PM
mrdahk's Avatar
mrdahk
Default Power steering problem
My power steering fluid in my 86 has a slightly metallic color to it, I'm told it's bad and something about a bearing going out. Any ideas?
Old Feb 15, 2009 | 03:01 PM
engle1147's Avatar
engle1147
Just looks like old oxidized fluid to me. If your having no problems with the unit I wouldn't mess with it until it leaks or breaks on its own. You could get a big suction style turkey baster thingy and suck as much fluid out as you can reach then refill the reservoir back to full.
Old Feb 15, 2009 | 04:10 PM
Iroc57's Avatar
Iroc57
If it aint broke...
Old Feb 15, 2009 | 04:30 PM
mrdahk's Avatar
mrdahk
It's not broken yet, but the guys at the shop said it was an issue. I'll give the turkey baster idea a go and see if that cleans it up.
Old Feb 15, 2009 | 06:07 PM
c4cruiser's Avatar
c4cruiser
It typically takes about 6-8 times with the turkey baster to get most all of the old fluid out. Slow, but it does work.
You can also remove the return hose going to the reservoir, start the engine and let it idle. That will begin to drain the reservoir, the rack and the pump. Turn the steering wheel back and forth slowly until you get a constant groan. That will indicate that everything is close to empty.
Then replace the hose, refill the reservoir with fresh fluid, start the engine, turn the steering wheel lock to lock, refill, rinse and repeat. You should probably do this once with cheap PS fluid before a final new fluid fill. Sort of like flushing the cooling system.
If you have a noise every time you turn the steering wheel, it could be the pump going south. The early C4 pumps can be pricey and rebuilds have been known to not be an exact replacement for the C4. You would also have to swap the pulley on a reman unit.
If you do a fluid flush, use something like Red Line synthetic PS fluid. I use it in my 87 for track days, and I don't have any issues with the fluid overheating or any noise. The pump is the original one.
Old Feb 15, 2009 | 11:00 PM
mrdahk's Avatar
mrdahk
I got most of it out, the color's much clearer now than it was, still a little dark, but much better. I'll drive it for a couple days and give yall an update, thanks for the suggestions.
mmmmmmm
Old Feb 16, 2009 | 04:35 PM
Steve59's Avatar
Steve59
My 87 PS fluid looks the same as yours. Not clear but kind of foggy. Had it replaced, still looks the same. No issues with the steering, so am going to drive it till something breaks.
Old Feb 16, 2009 | 05:38 PM
Weav's Vet's Avatar
Weav's Vet
Just looks like old oxidized fluid to me. You could get a big suction style turkey baster thingy and suck as much fluid out as you can reach then refill the reservoir back to full.
My steering didn't seem quite right and I did this only once. Seemed to help a lot. I'm going to do it again soon.
To Power steering problem
