89 code 33 Maf
Old Feb 25, 2009 | 06:12 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default 89 code 33 Maf
89 vette. Getting code 33, My scanner says. MAF to high. Yesterday, I put a new serpentine belt on and had my maf off. After I started it yesterday, here comes check engine light. Unplugged batt. Restarted. all good. On my way home from work today, here comes the CEL. Any suggestions?
Thanks all for your input.
Mike
Old Feb 26, 2009 | 10:28 AM
engle1147's Avatar
engle1147
Your car is telling you that the voltage is too high on the hot wire filiment in relation to the amount air flow through the unit. Clean or change the air filter(if running an oil charged filter do not over oil the filter) and clean the MAF's filiment with MAF cleaner. Remove any debris stuck to the screen on the front of the MAF's air flow intake side.
Old Feb 26, 2009 | 10:50 AM
tequilaboy's Avatar
tequilaboy
Re-check your connection at the MAF.
The MAF signal wire is pulled up to 5 volts by the ecm, so an open circuit on the signal wire will result in the MAF high fault.
Since you recently had this apart, it is possible that you bent a pin or somehow degraded the connection.
Old Feb 26, 2009 | 08:58 PM
CorvetteMike2024
Corvette Enthusiast
Default Maf
I cleaned the MAF with MAF cleaner last night. Drove to work and back today, all good. Checked all my connections.
I have owned this vette for 20 years. Seems like I have MAF issues about every two years. My car has 200,000 + miles. Still have the origanal TPS, IAC, and EGR.
Thanks for help
Corvette Mike
Old Feb 26, 2009 | 09:02 PM
engle1147's Avatar
engle1147
Thanks for help
Corvette Mike
I'm at ~250K.......
To 89 code 33 Maf
