What happened to this engine?
Old Mar 7, 2009 | 08:33 AM
jdraughn's Avatar
jdraughn
Default What happened to this engine?
http://img19.imageshack.us/img19/904...riversside.jpg
http://img18.imageshack.us/img18/179...sengerside.jpg
Old Mar 7, 2009 | 09:29 AM
mr.beachcomber's Avatar
mr.beachcomber
Default More Info Would Help!
Just judging from the two pictures and the amount of sludge/rust around all the coolant holes, I'd say that the coolant was run well past it's recommended change interval. Also, #3 cylinder appears to be washed down by unburned gas so I would suspect that the spark plug for that cylinder wasn't firing for a long time. You may have a blocked CAT if the unburned gas collected and burned there for any period of time.
More info on the engine would help. What did the cylinder heads look like when removed (for example)?
Old Mar 7, 2009 | 10:23 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
#3 may be so clean from water, cracked head? In general it looks like a major lack of maintenance. Both pics were of the drivers side so I don't know what the other side looks like.
Old Mar 7, 2009 | 10:30 AM
engle1147's Avatar
engle1147
To me, it looks like there was a lack of coolant or low to no flow of coolant into the heads on the back half of the engine. The rings burnt up and oil caked up.
Old Mar 7, 2009 | 11:17 AM
redrose's Avatar
redrose
need more info...first i wanna see the heads, look into ports for 'cones' of oil baked onto the backsides of intake and exhaust valves, indicative of high miles/valve guides worn/ seals shot...whoever pulled the head left water in #7 hole, rust shows in pic, may have already eaten cyl wall far enuf to need new piston/boring oversize (get some oil in there, stat)
Old Mar 7, 2009 | 11:33 AM
MikeC4's Avatar
MikeC4
What happened to this engine?....someone killed it....Burning oil.... piston rings are shot on #5 and #7. Compare these two cylinder heads to #1, which is the most normal looking.
How bad was the exhaust smoke prior to removing the heads ??
Man, you got the intake off and a bunch of leaves all over the place.....what's up wit dat ???
Old Mar 7, 2009 | 12:19 PM
tachout's Avatar
tachout
Just my opinion but with the leaves in there and the wiring all over, you had to leave this outside for quite some time while working on it. Without a closer look I have to agree that the bottom end is in need of rings, and would really like to see the heads now that they are back from the machine shop with a No Crack report. Would also like to see the old head gaskets..... Just me, but would want to know if they failed around the #3 hole.
Hope to run into you Sunday, and we can discuss. If it is going to need a bottom end, and you do not want to put a ton into it, I might have a sugestion or two for you on time saver sugestions too.
Old Mar 7, 2009 | 01:25 PM
MikeC4's Avatar
MikeC4
you may want to inspect your PCV valve. See if it is all gunked up or oil soaked. A nasty looking PCV valve would be further proof of "blow by" caused by worn rings.
Old Mar 7, 2009 | 05:25 PM
ChrisWhewell's Avatar
ChrisWhewell
my guess would be head gasket corrosion that permitted coolant into #3 cyl.
Old Mar 7, 2009 | 09:22 PM
Geeorge's Avatar
Geeorge
Looks like a blown head gasket to me too.
Notice how much carbon is on the other pistons,and that one is clean from the coolant breaking it loose.
May have been a simple valve job with milling the head and new gaskets.But now after letting it sit and collect debris and dirt it probably needs to be pulled and torn apart for a rebuild
Old Mar 8, 2009 | 06:52 AM
"swamp rat"'s Avatar
"swamp rat"
Yup ! I agree with that ! It's gonna have to come apart ! Complete rebuild or a crate engine ! I would go with the crate engine!!! Less time & Less hassle !!! It's your call !!!!!!
Old Mar 8, 2009 | 10:38 AM
jdraughn's Avatar
jdraughn
It was also frothing out of the oil dip stick tube.
To What happened to this engine?
