Cutting out!
Old May 4, 2009 | 01:16 PM
F8tBoy's Avatar
F8tBoy
Default Cutting out!
I'm getting a brief hesitation when I press the gas pedal about 1/4 the way down. If I let up off it or press down futher it catches. I also get a slight cut-out as if im loosing spark or have a dead spot in my fuel supply when im traveling at about 40-45 mph.
Thanks!
Old May 4, 2009 | 01:42 PM
engle1147's Avatar
engle1147
I'd look into putting a fuel pressure gauge on the fuel rail and take some pressure readings with the vacuum line on & off the fuel pressure regulator and check the bleed down times once the key is off to see is the system is holding pressure @ the rails.
Help us out and post the year of your vette and any other issues that may be related/wrong with the car.
Old May 4, 2009 | 02:05 PM
F8tBoy's Avatar
F8tBoy
Sorry, it's an 88 and thanks for your help..
Old May 4, 2009 | 06:15 PM
gruff1's Avatar
gruff1
I have the same issue happening. It's going into the shop tomorrow. I really don't want to just throw parts at the problem. I'll post the solution to my issue as soon as I find out.
Old May 5, 2009 | 06:32 AM
F8tBoy's Avatar
F8tBoy
Thanks,
Old May 5, 2009 | 02:13 PM
gruff1's Avatar
gruff1
In my case (94 LT1) it was a faulty o2 sensor.
Old May 6, 2009 | 10:52 AM
F8tBoy's Avatar
F8tBoy
Thanks..
Old May 6, 2009 | 02:30 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
a4 or stick?
A TV cable that is not adjusted properly on a a4, will give you that feeling.
Old May 6, 2009 | 03:00 PM
gruff1's Avatar
gruff1
Mine is an A4.
To Cutting out!
