HSR Numbers
Old Jun 10, 2009 | 09:02 PM
qws's Avatar
qws
Default HSR Numbers
Got my (free) HSR today from Holley. Sweet! And thank you to HOLLEY!
Anyways been reading up on it, they claim a 63hp gain when bolted onto a stock 350. Is this BS or does anyone actually have some numbers they'd like to share.
Old Jun 10, 2009 | 09:37 PM
Pwnage1337's Avatar
Pwnage1337
i don't know a whole lot about dynos and such, but you know how the TPI's die at 4100ish rpm? They probably make 60 hp more at 4300 rpm or something like that.
how did you get one free? I WANT ONE!
Edit: Just watched your video, is that the motorsports body kit?
nice pull!
Old Jun 10, 2009 | 10:03 PM
qws's Avatar
qws
nice pull!
I won one of the holley carbs in the promotion 52 carbs in 52 weeks. Well really didn't want a carb. So they were nice enough to work out a sweet deal with me. Most parts but a couple minor things to buy. Nothing major.
The body kit is from mold kraft and thanks for the comment on the vid
Old Jun 10, 2009 | 10:26 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I have no problem believing 50-60+ add'l hp by swapping to the HSR.
Lot's of comparisons here:
http://www.stealthram.com
An article written by BADSS:
http://www.gmhightechperformance.com...roc/index.html
And the peeace-a-da-resistance...Justin's detailed how-to and results:
http://www.thirdgen.org/techboard/al...ealth-ram.html
Read and get excited about your new intake!
gp
Old Jun 11, 2009 | 09:26 AM
qws's Avatar
qws
That GM article is the one I'm getting my info from. Its just that it sounds to good to be true.
I measured it up last night and its approximently 1.5 inches taller than my CFI setup. So with my scoop I should have at least another 1.5 inches above the HSR.
With the stock bottom end would I be better off using 24lb or 30lb injectors?
I was thinking of just going ahead and getting the 30lb. Planning in the next year or two dropping the 383 in so i'd rather not buy injectors twice.
thanks
Old Jun 11, 2009 | 12:29 PM
tmichaud's Avatar
tmichaud
nice pull!
The 60 hp might be right, but the above is not correct. The HP advantage would not be at the same rpm level. The HSR allows the motor to breath at higher rpm's. This allows the motor to keep torque going at the higher rpms, and as we all know HP=tq x rpm/5252.
Since the stock TPI dies at 4500ish and the HSR can go 6000+ the effect would be drastic.
Old Jun 11, 2009 | 03:20 PM
aklim's Avatar
aklim
But unless you cut your hood like I did, the HSR will not fit. Some company, UMC (??) supposedly has a cut HSR. Does anyone know how different it is from the original HSR that Holley sells?
Old Jun 11, 2009 | 04:20 PM
qws's Avatar
qws
As I stated hood clearance isn't a problem
Hes my sig again
Old Jun 11, 2009 | 04:24 PM
pologreen1's Avatar
pologreen1
wow, congrats man that is sweet, and really cool that they gave you a stealth ram instead. DAMN
Old Jun 11, 2009 | 04:56 PM
aklim's Avatar
aklim
Hes my sig again
My car is white and I did EXACTLY what you did with the Greenwood hood scoop.
Old Jun 11, 2009 | 05:06 PM
LD85's Avatar
LD85
Hes my sig again
You will love it, remember that you can bring the fuel lines into the front, as normal, you might have to make a short section of braided line with a fitting that will fit the stock line and the Holley fuel rail.
Also, you can use a Throttle body spacer if you have a linkage clearance issue with your Throttle Body.
Old Jun 11, 2009 | 06:24 PM
qws's Avatar
qws
That was gonna to be one of my questions, I figured there was a way to do it without cutting them back, thanks
Old Jun 11, 2009 | 06:49 PM
LD85's Avatar
LD85
Summit and Earls sells the tpi thread to AN adapter
http://cgi.ebay.com/ebaymotors/AN-6-...QQcmdZViewItem
To HSR Numbers
