Im replacing my cat back pipes/mufflers. I cant get it loose, the bolt will twist enought so that I cant get it to pop.
clamp a vise grip on there hard it doesn't matter if you bogger up the threads since you won't need good threads for the nut to bite, don't worry you can get it out, witha vise grip and you won't even have to hold it once it rotates to a wedged position.
Lots of WD40 or penetrating oil and an air gun should get it off. If the bolt twists too much because of it's length, use vice grips on the shank of the bolt as recommended above.
Cant get a socket on it, so cant get impact on it. The bolt is not rotating per say, it's acting like a spring. I can only get a 9/16 box wrench and very little leverage. I really think it is a 2 sided stud with a flat washer like place that holds the narrow bracket to the cat and with a longer stud which is visable coming back to the exhaust pipe. I'm thinking if I can get the pipe out of the way maybe I can break loose the rest of the stud from the cat with a small pipe wrench and then replace with a bolt.
I ran into this just a couple of weeks ago. I cut the existing stud off with a cutoff wheel leaving just about 1/16th of an inch sticking out so I could find the center. I then center punched it and drilled it out with progressively larger bits until I got to the right size for the tap. I bought the new studs from NAPA. Have a good set of bits and use plenty of spray lube because the metal will be somewhat hardend from the heat.
I got them I took the torch and heated the pi$$ out of the nuts. They gave up the grip. Definitely a RPITA It's amazing what cooperation you get when you put a torch to the nuts
Thanks for all who helped.
If you put a torch to your nuts, you would give up the grip too.
Finally found a use for the small MAPP set up I've had for years - exhaust system bolts and nuts. Heat until they glow red and twist them right off. Only way I could get the exhaust off my car to do the propeller shaft u-joints.
use a dremel tool or a drill with a small stone or cutting wheel in it.
grind off one flat from the frozen nut; grind just until the threads
on the stud begin to show.
take a hammer and drift punch, smack the nut sharply with the intent of "spreading" the nut apart; this will seperate the bond of rust between the nut and stud.
this is almost always is successful and works where heat has failed (or is unsafe to try) and will save an otherwise servicable stud where a breaker bar and six sided socket (or impact gun) can result in a broken stud with all the attendant problems of broken stud removal, drilling and retapping, etc.
clean the threads of the stud; apply copius amounts of anti-seize, install a brass nut (or two, using the second as a lock nut)
From your photo, the stud looks servicable, I'd say give this a try, if it fails, nothing is lost and you can always go to plan "B".
good luck
I've already taken care of mine by heating and yes they were serviceable at least for the time. I'll be replacing the whole system when my headers get here. That is good info though. I'm sure someone will benefit from it.
