Does yours vibrate
Old Feb 16, 2002 | 12:35 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: Does yours vibrate (Kieran ***)
Why is the survey only apply to LT4 Vettes if you don't mind me asking?
I have two C4 Vettes but no LT4 in either.
Old Feb 16, 2002 | 01:23 AM
Bgreenard's Avatar
Bgreenard
Go Fast
Default Re: Does yours vibrate (VetNutJim)
My LT1 is solid to 110 then I get a small vibration but nothing I dont consider normal for that speed.....................
Old Feb 16, 2002 | 11:07 AM
LayZ's Avatar
LayZ
Default Re: Does yours vibrate (thedevl)
It vibrates but nothing like it use to. I had bad vibration once it got up to 50 it would shake and rattle. I had all four tires balanced, checked for roundness and bent rims. The tire guy had said vette's were prone to throw the weights off. It's alot better but i still get a little. Not sure if it is drivetrain related but that is the next step. A body shop guy suggested a brace like in a convertable.
Old Feb 16, 2002 | 11:22 AM
LT4BUD's Avatar
LT4BUD
Default Re: Does yours vibrate (dexion)
Same observation regarding 4.10 gears. Before the 4.10's the car vibrated from about 80mph on up, but since the gear change it seems to have gone away. I was afraid if it was driveshaft speed it would come in at lower speed but same driveshaft rpm. I need to go out & confirm what is going on, but I do believe the 4.10's may have eliminated the vibration. While changing the gears I checked balance on driveshaft, half shafts, & wheels. All were perfect.
Old Feb 16, 2002 | 08:46 PM
Ron04,02,96,64's Avatar
Ron04,02,96,64
I voted "no vibration with my LT4" at any speed :)
Old Feb 16, 2002 | 11:06 PM
ROME's Avatar
ROME
1989 Coupe here. Modified ZZ3 has taken the place of the L-98, but I still have the shake around 75-80 mph. I'm prioritizing some tranny mods right now, so the slight vibration will have to wait a bit (unless it IS in the tranny, which I doubt is the case).
I'll be balancing the wheels, then checking the front ball joints and swapping the rear U-joints if need be.
Rome
Old Feb 17, 2002 | 08:19 AM
Vvcdde's Avatar
Vvcdde
While I do have the camber brace installed (and loving it!), my car still does rattle. This is just a common place in older cars. This could be a 95 Bently and I am sure it would still rattle. It is just the nature of the beast when dealing with older cars. Now this doesn't mean I don't try to curtail the rattles at every point. Nothing pisses me off more than one stupid little rattle.
Old Feb 19, 2002 | 10:43 AM
thedevl's Avatar
thedevl
So far I've only seen one header with a CARB number assigned to it, and that's hooker shortys. To my knowledge, no long tubes are legal in California and you won't pass the visual with replacement cats unless the car is over 7 years old (I think). The warranty from the MFG for the cats is somewhere around 7 years, and after that I believe you can replace them with aftermarket. Good Luck
Flynn :reddevil
Old Feb 19, 2002 | 10:47 AM
thedevl's Avatar
thedevl
Actually, It started out for LT1s and LT4s because there were changes made going to the LT1/4 series that I was not sure would translate over. I was more curious about the LT1/4 combo because I have an LT4 and it vibrates and has from day one with several attempts to get rid of the problem. I have yet to hear from anyone that has had this particular type vibration succesfully get rid of it. I was looking to see how common it is on the LT1/4 but other people have added the L98, which is good as it shows a problem that seems to cross the lines of the whole C4 production run.
Flynn :reddevil
Old Feb 19, 2002 | 10:49 AM
Knight Ryder's Avatar
Knight Ryder
St. Jude Donor '05-'06-'07-'08
I had a humming sound between 74-76 mph that resonated throughout the entire cabin. It has gone away, but because I have only had the car since late August, I cannot say if weather, etc. plays a role.
Old Feb 19, 2002 | 10:51 AM
thedevl's Avatar
thedevl
Default Re: Does yours vibrate (Vvcdde)
I was looking for a particular type vibration based on characteristics described above, not rattles, but thanks anyway
Flynn :reddevil
Old Feb 19, 2002 | 12:22 PM
thedevl's Avatar
thedevl
Default Re: Does yours vibrate (Knight Ryder)
Here's the link for the rest of the story and my progress to date.
http://forums.corvetteforum.com/zerothread?id=234718
Flynn :reddevil
[Modified by thedevl, 8:23 AM 2/19/2002]
Old Feb 21, 2002 | 02:04 AM
  #33
yellavette94's Avatar
yellavette94
Mild vibration from the rear at 75-85 but doesn't affect drivability and seems to calm down as speed increases. Had her to 132 with no noticeable malfunctions.
Old Feb 21, 2002 | 02:55 PM
  #34
thedevl's Avatar
thedevl
Well, it looks like about 50% of our cars vibrates. Sounds like a real design problem, huh. I would still like to hear from some of you that have had this and fixed it. It appears that no one has eliminated this problem.
Speak up if you have, and note that it is not tires, or rims, or u joints or bearings or half shafts. I will get my driveshaft back today from having it balanced and we will see if that helps.
Flynn :reddevil
Old Feb 21, 2002 | 08:35 PM
  #35
lead foot 85 vet's Avatar
lead foot 85 vet
I'm In on the it vibrates side..... 85 L98....tried the driveline rebalance...replaced the ujoints....rebuilt the dana 44.....its more of a noise than a big vibration but I wanted it gone...makes me a little uncomfortable at 140 mph I'd hate to have something break....might ruin my hole day
Old Feb 22, 2002 | 03:53 PM
  #36
thedevl's Avatar
thedevl
Default Re: Does yours vibrate (lead foot 85 vet)
If you go read the thread started by Cire96 about LT4 vibration, you will see where I am on getting rid of this. I have finally found something wrong.
Fl;ynn :reddevil
Old Feb 24, 2002 | 09:12 AM
  #37
DenverLT4's Avatar
DenverLT4
Add me to the vibrate list at 50 to 60. It's something that started resently. Had the tires rebalanced and that reduced it some. I think it's time to have an alinment. The tires are about ready for replacement also.
To Does yours vibrate
Old Feb 24, 2002 | 01:54 PM
  #38
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default Re: Does yours vibrate (DenverLT4)
I voted,l98 does vibrate a little. I think somewhere around 110mph.
It is MUCh better now that the driveshaft is balanced.
I also know that i have a bent rim. I am afraid that the rim might be ruined
if i have it fixed,they say it happens sometimes when trying it.
So i just stop short of 110!!!!!! :D :D
Matt
Old Feb 24, 2002 | 03:46 PM
  #39
Kieran Cox's Avatar
Kieran Cox
Default Re: Does yours vibrate (6spd.89)
Hey guys, I bought this lifetime alignment from Firestone for about $150. It is good for the rest of your ownership of your car. Do they realize how often I will be in there for a balance???
Old Feb 24, 2002 | 03:49 PM
  #40
GlockLT4's Avatar
GlockLT4
I was thinking about getting that tool. One heck of a deal for us with our cars!!
