Installing the 421.....
Old Jul 27, 2009 | 10:22 AM
88BlackZ-51's Avatar
88BlackZ-51
Originally Posted by dclafleur
I hear ya, I keep going back and forth on if I should get a beefier transmission first then build a big motor, or if I should get the big motor and see how long it takes for me to demolish my 4+3.
Well the motor is going to cost alot more then any tranny. I had a plan, but UPS certainly changed my plans. I am waiting for my money back on the tranny then I will hunt for another one.
If your looking for someone to build you a stroker like mine, look no further then Jim. He is a genuine nice guy, and most importantly has been there, and done that with these motors. You can always call me if you have any questions.
Old Jul 27, 2009 | 01:25 PM
88BlackZ-51
Plenty of guys have hot strokers up to 400ci and more with the stocker just gotta know what youre doing and spend the time. Now Im sure the FAST may have better features, just saying its not impossible....
The 408 I just did (with wilder cam timing) will be tuned with a stock ECM. Do what you think is best, Im sure Jim knows whats going on as he does it for a living. Keep us posted.
Time will tell Ron. I downloaded the program for the FAST, and there is alot of cool features. I "think" the time and money I would of invested in tuning with the stock ecm is why I went aftermarket.
Old Jul 27, 2009 | 02:48 PM
Vette Threat's Avatar
Vette Threat
Lookin' good
You should hold a contest to see how many pulls you 4+3 will last before it blows up
Old Jul 27, 2009 | 05:01 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
If you drag race it the 4+3 is a goner...but for highway pulls and roll outs I was putting 650++lbft thru my 4+3 and the tranny was fine. I got a crappy rebuild on the OD so it never worked right but when engaged correctly it held fine up to some pretty hard pulls.
Old Jul 27, 2009 | 05:16 PM
Orr89rocz's Avatar
Orr89rocz
Looks good man. Should be a nice combination
Old Jul 27, 2009 | 07:01 PM
C409's Avatar
C409
[/QUOTE]I will take some pictures along the way for chits and giggles.[QUOTE]
Old Jul 27, 2009 | 08:23 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Good good, glad to see you're moving along. I've never done a stand alone EFI harness, but with regular harnesses I always thought it was easier to wire them up before the motor goes in, no? (I'd like to know as some day I may very well be going to FAST/DFI/XFI etc)
Old Jul 27, 2009 | 09:37 PM
pipe's Avatar
pipe
I like your combo Rick I wish now I would have went bigger cu. in. instead of my 383 but it's got really good parts in it and great heads. Anyway does anyone have that DVD that FAST puts out about their systems? I have a Mini Ram setup and thought about going to the FAST system with the single plane and their billet TB. Rick what oil pan is on your motor? THANKS Pipe
Old Jul 27, 2009 | 10:11 PM
88BlackZ-51
That is somewhat good news. So it's the clutch drops at the track off the line that kills them?
Well the 4+3 is all buttoned up, so it is staying put. How long it stays in is anyone's guess.
Old Jul 27, 2009 | 10:21 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Must be good to be soo close; bet you have a big smile when she fires up...
Old Jul 27, 2009 | 11:14 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
The Super T10 isn't a bad tranny, just not meant for the kind of abuse youre capable of dishing out.
Do not use the auto kick down or it'll be toast inside of a week.
Old Jul 28, 2009 | 08:22 AM
88BlackZ-51
10-4.
I haven't used that auto kick down in years, and I also disconnected the auto portion for my auto cross events.
Old Jul 28, 2009 | 12:35 PM
  #33
AKS Racing's Avatar
AKS Racing
The aftermarket EFI systems are not terribly hard to wire up. I will say it would be a bit easier without the engine in place, but overall, not too much difference.
Rick,
Have you decided where you are going to mount the FAST unit?
Old Jul 28, 2009 | 02:07 PM
  #34
LD85's Avatar
LD85
Dos the FAST work with the MAF?
Old Jul 28, 2009 | 02:28 PM
  #35
88BlackZ-51
Rick,
We will decide that when I take the dash out. But we do want 2 use the fuse located to locate the tuning cable. I think that spot is clean, and out of the way and easily accesible for tuning purposes.
I might be wrong, but I think you have a FAST or GEN 7 as well, and if so where did you mount the unit?
Old Jul 28, 2009 | 02:32 PM
  #36
88BlackZ-51
I have a sequential MSD distributor. The FAST won't work with the MAF. I need to find another unit to feed the Holley TB.
Any suggestions?
Old Jul 28, 2009 | 03:17 PM
  #37
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Any suggestions?
Would it be hard to convert to a speed density setup? Or is it too late now that then engine is assembled.
To Installing the 421.....
Old Jul 28, 2009 | 03:41 PM
  #38
jerkyboy's Avatar
jerkyboy
Just need a MAP sensor and vacuum lines. Rick, what are you going to do to keep the dash gauges going? You will need a piggy back harness I believe. I mounted the accel box and the stock ECM together behind the seats
Old Jul 28, 2009 | 06:40 PM
  #39
pr0zac's Avatar
pr0zac
i think that you are going to have to mount it in the passenger side under the dash. there is some room under there on the older cars. it will be easier then having to run the wire from the driverside which is all cluttered and narrow enough as it is. you will have to have the laptop in the passenger seat anyways. stand alones are a bitch. i would suggest something that piggy backs your stock harness for the sake of making it easier on everyone.
Old Jul 28, 2009 | 10:06 PM
  #40
88BlackZ-51
So it turns out that my wicked looking Chevrolet covers won't clear the wiper motor. I knew they were a tall design, but I didnt think they would sit that tall. So inturn they are for sale. If anyone is interested, send me a pm.
Tonight I threw on a set of valve covers that have been sitting in a closet for a while. It appears that I will have to go with them. I took a few pictures of the motor as it sits. Curious what you guys think?
The car is towed home, and is parked in my driveway until I have time to get back at it. This certainly is going to be quite the project, but I am sure it will be all worth it.
Take care guys!
