distributer woes
Old Jul 28, 2009 | 10:03 PM
rtmpmm's Avatar
rtmpmm
Default distributer woes
well ive changed the intake and plenom gaskets now i cant get the car to run, ive pulled the distributor out and back in 1o times the only way i can get it to barley run is if i have it turned so far back that the nub where the wires plug into the hei almost touch the fire wall im pulling my hair out, could i just be off one tooth, where should that hei plugs be? pointing twords the drivers side right?
Old Jul 28, 2009 | 10:29 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I posted a link for spark wires and info here >> http://forums.corvetteforum.com/c4-t...-position.html
You might find it useful.
Old Jul 28, 2009 | 11:21 PM
rtmpmm's Avatar
rtmpmm
what do i unplug to set the base timing?
Old Jul 28, 2009 | 11:39 PM
Pwnage1337's Avatar
Pwnage1337
you unplug the EST connector, it is by the brake booster. one little "male end" into a "female end"
if i'm correct it has a brown wire. dont quote me
Old Jul 28, 2009 | 11:44 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
remember, rotate the distributor clockwise to retard the timing, and rotate counterclockwise to advance.
Old Jul 29, 2009 | 01:22 AM
383vett's Avatar
383vett
If you have had your distributor in and out 10 times, it sounds like you are just guessing or hoping the distributor and rotor will line itself up and the car will run. Pull the distributor and turn the motor over to tdc with the #1 valves closed. Put the distributor in with the rotor pointed to the #1 plug wire. This will get you close. See if you can get the car started. You may need to rotate the distributor a few degrees either way. Once it runs, unplug the previously mentioned wire and use a timing light and time the motor to 6 degrees btdc or whatever. Tighten up the distributor, reconnect the connector and go driving. Good luck.
Old Jul 29, 2009 | 09:14 AM
Chapindad's Avatar
Chapindad
I Agree!
Also realize that the oil sling in the bottom is not tied to anything, so it is probably off alignment with the timing and you will need to realign it once you know where the #1 position is on the car.
Old Jul 29, 2009 | 10:22 AM
engle1147's Avatar
engle1147
Originally Posted by Chapindad
I Agree!
Use a long screwdriver or oil pump primer to rotate the oil pump's shaft extension counter clockwise to get it to drop in on the correct cam/distributor tooth set you want.....it is not difficult after you embrace the fact that everything rotates as it is dropped in....factor a partial rotation until/before engagement when adjusting the pump shaft.
Old Jul 29, 2009 | 10:24 AM
cfi's Avatar
cfi
Pawnage13337 is correct. So you can quote him.
89 coupe
Old Jul 29, 2009 | 02:02 PM
rtmpmm's Avatar
rtmpmm
ive had it at top dead center, put the dist in, and it will only start if i advance the dist as far as it will go but it dies out in idle i have to be a tooth off
Old Jul 29, 2009 | 03:20 PM
383vett's Avatar
383vett
Loosen the distributor and carefully pull it out. When the rotor stops turning move it slightly clockwise and reseat the distributor. This will move it one tooth advanced (if you're that far off, you may need to shoot for 2 teeth. Turn the motor until the distributor drops and is completely seated (oil pump engauged). Snug it up, put the cap on and try running it now.
Old Jul 29, 2009 | 05:31 PM
AGENT 86's Avatar
AGENT 86
Did you look at the thread I linked you to ??
Old Aug 7, 2009 | 08:49 AM
gerardvg's Avatar
gerardvg
I have always marked the distributor and inlet manifold then rotor position . nearly all the time the sistributor doesnt go back in properly and you need to turn the oil pump shaft a bit to get the distributor in corectly ... so next time mark it with a texta or scrape a spot and you cant go wrong . so when you get it at tdc and put rhe distributor in you will find there is a mark on the inlet manifold for the rotor button to lign up with . in future it will be easy if you mark the position before removal and your setting wont have changed
good luck
Old Aug 7, 2009 | 09:14 AM
rtmpmm's Avatar
rtmpmm
Car is timed now but idles rough when warmed up jst changed wires cap rotor o2 sensor cleaned iac new fuel pump, when running i put a vacuum gauge on regulator hose shows zero vacuum on air pump vacuum line shows 15-17 hg what do i do now?
Old Aug 7, 2009 | 09:43 AM
AGENT 86's Avatar
AGENT 86
That's weird, because those 2 share a common port on plenum (factory routing).
Pull the vacuum line to reg and check if it's clear of debris ??
Old Aug 7, 2009 | 10:12 AM
rtmpmm's Avatar
rtmpmm
I checked it no obstruction i also hsve no vacuum at canistor near charcoal canistor?
Old Aug 7, 2009 | 10:15 AM
AGENT 86's Avatar
AGENT 86
replied to your other thread.
To distributer woes
