Air Intake system question.
Old Jul 14, 2010 | 12:46 PM
  #61
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
Originally Posted by 88BlackZ-51
i still need to find something that connects the TB to the stock airbox. any suggestions? this is the last piece in my puzzle.
Will you be running a MAF sensor, or is the FAST system SD?
You could use your original throttle body-to-MAF sensor tubing (just need to stretch it out a bit to fit over the 58mm TB) and then buy the correct size & length tubing to connect the other end to the factory air box (would need to use a bushing to join the two tubes).
Old Jul 14, 2010 | 12:50 PM
  #62
88BlackZ-51's Avatar
88BlackZ-51
MAP sensor Dan. The FAST is a full seq. unit.
I also have the Holley 58MM TB. I'll think about your idea.
Old Jul 22, 2010 | 02:53 PM
  #63
88BlackZ-51
It looks like i might be getting an airbox fabricated out of 0.080 aluminum. if it works out, would anyone else be interested.
It will look similar to this with the Camaro filter attached.
I am thinking this will move more air into the TB. I am also thinking of a complete system right 2 the TB.
Old Jul 22, 2010 | 08:25 PM
  #64
DanZ51's Avatar
DanZ51
Pix link no worky...
Old Jul 23, 2010 | 03:31 AM
  #65
tim32920's Avatar
tim32920
I put the claw on mine and to tell the truth, I did NOT see any difference from when I cut the top off the old air box with and a K&N filter. So don't waste your money on hype.
Old Jul 23, 2010 | 04:24 AM
  #66
JCDVette's Avatar
JCDVette
so i looked at a lot of the post on this thread and all I figured out was that there is nothing that works for the c4? that it is all a waste of money?
this is the one thing that i dont like about asking guestions on forums. you never seem to get a simple answer. it is always try this...(next guy) that wont work.
If you have a intake system on your car feel free to voice your opinion. but all the other crap is a waste of time for the posters.
Thanks.
