Air Intake system question.
Old Aug 21, 2009 | 09:47 PM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Originally Posted by locobob
The stock system actually flows pretty well:
http://forums.corvetteforum.com/c4-t...o-results.html
To get the true effect of the cold air intakes mentioned above, you have to have cool air coming in. I looked over the link and didn't see any mention of the use of a fan. All of the cold air intakes need to have a large fan in front blowing outside air to the area of the intake simulating the movement of the car.
Old Aug 21, 2009 | 09:48 PM
NocarbutaVetteforme
To the Op, you may want to see if Vararam has their unit for sale yet.
Old Aug 21, 2009 | 09:53 PM
88BlackZ-51's Avatar
88BlackZ-51
Originally Posted by AKS Racing
For years I ran a system that was ordered from either MAD or Ecklers that was basically the factory system flipped over and enlarged with the later model (larger) K&N with a ram air vent that was down inside the radiator area.
It worked well, but sold it to someone on here for like $275 a few years back.
It doesn't work in FI applications, so no longer needed.
If you could find a system like that, I think you would be satisfied.
If only I could find one for sale. Interesting post Aaron.
Old Aug 21, 2009 | 09:54 PM
88BlackZ-51
They were supposed to have that for sale 2-3 years ago if my memory is correct. I was told a while back that there will not be a C4 unit?
Old Aug 21, 2009 | 09:58 PM
NocarbutaVetteforme
Yeah, they do seem to be dragging their feet. You would think that they would see the potential of all the C4s out there. I checked their website and didn't see anything at all.
Old Aug 21, 2009 | 10:01 PM
88BlackZ-51
I just did the same. I also emailed the company, but I am not holding my breath. I don't blame them as the typical C4 owner is cheap, and they might of thought they wouldn't sell many units, or they couldnt figure out a good system to keep there positive name.
Kinda sucks because it seems hard to find a system that works. I will figure out something.
Old Aug 22, 2009 | 06:27 AM
88BlackZ-51
Originally Posted by GKK
Just use a stock Air filter box and Air Coupler tube from a Speed Density L98.
Cut out the air filter lid and install any high performance filter you want and it'll be enough air for your 421.
Will the air coupler tube work since my car is an 88? It seems that the opening of the air intake is larger in the 90-91 cars?
Old Aug 22, 2009 | 08:18 AM
mseven's Avatar
mseven
with some work something this might be an option
(scroll down link)
http://www.thefind.com/cars/info-slp...page=2&local=0
SLP Blackwing Air-Box Lid, 2000-'02 V8 Camaro/FirebirdSLP Blackwing Air-Box Lid, 2000-'02 V8 Camaro/Firebird [21045] $99.95, or the complete kit next to it.
Old Aug 22, 2009 | 11:22 AM
GKK's Avatar
GKK
I should've been a little more specific. You need to use a Stock Air Filter Lid from a 90-91 Speed Density C4 Vette.
Old Aug 22, 2009 | 09:14 PM
88BlackZ-51
I understand and thanks, but from what I read the 90-96 rad/housing has a different angle so I don't see how a stock filter lid would fit my 88?
If you are positive that it will work, then I will probably go this route.
Old Aug 23, 2009 | 12:14 AM
black_89_vette's Avatar
black_89_vette
Hey Rick, if you're upgrading your air intake system, is your stock air filter housing for sale?
One of the "ears" that holds down the air filter cover is broken on mine on one side.
Old Aug 23, 2009 | 02:14 AM
GKK's Avatar
GKK
Yes, the 90-91 radiator is at a slightly different angle than the earlier years.
With a heat gun, the plastic air filter base could be re-contoured to fit the different angle.
Old Aug 23, 2009 | 09:00 AM
  #33
Aurora40's Avatar
Aurora40
I cut out the filter lit about 5 years ago, and it has a K&N, but I don't think I am far off saying that the 421 will need more air then the stock 350.
I would like to do something to improve air flow, I just don't know what.
Why not test it and find out? Stuff like the SLP ram air shroud on the same filter and housing is not going to flow more air. If anything, the entrance to it is smaller than a cut-lid. But it definitely pulls outside air.
You have a MAP sensor, so datalog the car. See what the air pressure is with the engine off to baseline the ambient pressure. Then run the car through one gear at WOT. Look at how low the pressure goes from the baseline up to high rpm. If it doesn't drop more than 1-2 kPa, you don't need a bigger intake.
Old Aug 23, 2009 | 01:30 PM
  #34
tequilaboy's Avatar
tequilaboy
Similar to Mick's suggestion, I would try something like this:
http://www.corvetteguys.com/gms-0104-dual-cone-cai.html
But, I would also add a 90 degree tube running through a hole cut in the shrowd, and locate the filters underneath the shrowd and exposed to the cold air.
Your aux fan and impact bar may be in the way of the filters, however, so you would want to check the available space first.
Old Aug 23, 2009 | 10:01 PM
  #35
LT4BUD's Avatar
LT4BUD
Curious how you come up with 1-2kPa as a criteria????
Ideal would be no drop....do you know what the horsepower correction factor would be with a 1-2KPa drop???? my gut feeling is it is not large, but it is signification??
Old Aug 23, 2009 | 10:25 PM
  #36
pologreen1's Avatar
pologreen1
I have one called corvette ramair, it is basicly a 3piece K&N unit like the claw, with a box, and a tunnel scoop built around it that goes under the front of the car.
It was very very expensive, and I have only heardof one other on a google search, and never seen pics except mine.
Technicly you could get an slp claw, and have a similar setup made, by boxing in the thing with a rectagle scoop that goes all the way through the front.
It has a template that you use to cut out the radiator shroud though, to let it sit down in, and under the car.
good luck.
I also have a stock 90' air box and cutlid for sale cheap if intrested
Old Aug 23, 2009 | 10:53 PM
  #37
Aurora40's Avatar
Aurora40
Ambient is in the ballpark of 100kPa. So you are talking 1-2%. On a 500hp car, that is 5-10hp.
You will always have some pressure drop on a naturally aspirated motor. But that number is just a gut number.
To Air Intake system question.
Old Aug 24, 2009 | 06:37 AM
  #38
88BlackZ-51
I like your idea, but it's alot to spend for something that "might" work.
Thanks.
Old Aug 24, 2009 | 08:06 AM
  #39
jeffp1167's Avatar
jeffp1167
I'm curious about these and if they actually work. Stock filter is in a cold air area, no matter how much air you "ram" in there the total filter surface area predicts how much air can actually enter and a stock filter has way more surface area then any of these.
I personally dont see how any of these would make any more power then the stock setup. If you meet the demand of how much air the engine demands at specific rpms, the how much air a filter can pass is all that matters and even 3 cone k & n filters doesnt come close to what the square stock filter can let through.
or am I wrong ????
Old Aug 24, 2009 | 08:16 AM
  #40
LT4BUD's Avatar
LT4BUD
Originally Posted by jeffp1167
.......the how much air a filter can pass is all that matters and even 3 cone k & n filters doesnt come close to what the square stock filter can let through.
or am I wrong ????
FYI the total surface area of the 3 cones used on the SLP system virtually identical to the stock filter....at least on my 1996
