1984 head light problem
Old Aug 22, 2009 | 03:17 PM
1984vetteowner's Avatar
1984vetteowner
5th Gear
Default 1984 head light problem
with the head lights on they come up than about a minute or two later a click
9wine) comes from passingers side and the lights seem to blink then happens again after a minute could this be the relays inside the motors are bad? the master relay stuck thoughts or ideas welcomed
Old Aug 26, 2009 | 12:02 PM
woody1243's Avatar
woody1243
Not enough info. Can you explain better?
Woody
Old Aug 26, 2009 | 12:26 PM
nitronick's Avatar
nitronick
Active Streak: 90 Days
Woody
I'm sure it made perfect sense in his head, but I got nuttin' either
Old Aug 26, 2009 | 12:55 PM
jhammons01's Avatar
jhammons01
http://forums.corvetteforum.com/c4-t...air-w-pic.html
Old Aug 30, 2009 | 10:21 AM
1984vetteowner
5th Gear
can you read the discouragement? thanks for taking the time to help me with this!! the headlights come on then pop up then a clicking sound can be heard and the headlight seem to dim (like a relay is clicking some where) then the headlight stops dimming then after a minute or two it makes that noise (like a click of a relay making) and dims again has a pattern to it (not like a short then that is random) I think these type of motors have a relay built into them? or could it be the master headlight relay by the drivers wheel well (has three of them ) the motors seem to raise and lower the headlights ok
Old Aug 31, 2009 | 09:15 AM
AGENT 86's Avatar
AGENT 86
I have not tore into one of mine, so I'm guessing when I say,
"It sounds like a limit switch in motor housing is allowing the motor to keep trying to move the bucket, causing a internal circuit breaker to trip. When the breaker cools, the motor tries again. This constant, load-no load, could be causing the dimming headlight."
Here is the electrical schematic for the doors, might help to rule out that end, first.
http://members.shaw.ca/dankai/Headlight%20Doors.pdf
Old Sep 1, 2009 | 08:09 PM
1984vetteowner
5th Gear
quick reply thanks for the info. i have not got back to vette, put i had motor apart replacing the gears when i got the car. i did not know what i was looking at (limit switch) i though was some kind of relay. possible cause and effect? thanks again for everyone that read and posted to this :
To 1984 head light problem
