Cruse Engagement Problem for 94
My first suspects are the cruise control module (berried in car), or the servo unit under the hood. All my hoses appear to be good and 3 way check valve is OK. Definitely seems to be a (electrical) heat related problem.
Since then I have connections for the 2 relays in the servo and brought them into the car so I can monitor the voltages during activation. When working I can see the 12 volts being applied when the cruse works properly. When the problem occurs the applied voltage is only 4-6 volts and varies on both relays. So obviously my problem is in the cruise module and not the servo. Seems to be a common problems to both circuits so perhaps the fix is achievable as possible regulator of feed of some sort.
I am going to try the repair the unit but just have not got it out yet. Its more work than I thought and may not get it out till the weekend. Question is, has anybody been into these units to repair and had any success. If I can’t fix it I might just have to buy one.
I have had some success repairing some of the other boxes in the car however without the schematic and the proprietary parts that they use makes some of the repairs tough even though I work on electronics on a daily basis.
Basically diagnosing is slow as I have to drive with a couple of volt meters in the car monitoring various points and waiting for problem to occur. Each day I accumulate more information building a picture of what is happening. (Things just hanging out of the passenger side).
So far the only symptom I have found is the disengage input to pin G of the module drops to about 6 volts when the problem occurs which is probably the reason I am loosing voltage to the servo relays. I have ohmed out the brake pedal switch and cruse cut off relay where this voltage comes from (into pin G). The continuity path is about 1 ohm which is good.
So far when monitoring the main voltage feed to pin A of the module seems to be OK at least at this time. However I could not get the problem to occur while monitoring this point. I am going go stick with monitoring the 2 voltage inputs as I think something will show up here. Not sure yet if it is a supply problem or something is loading the voltage down.
Just to be on the safe side I found a deal on a cruise module so I have ordered one. Will get it next week and will try it unless I find the problem. Now the problem seems to happen when its not that hot outside.
I don’t really expect many comments on my posts. I just want to keep my progress posted as some of the more technical people might like to follow along. Pages 8A-34-0 & 1.
Long story short:
My switches on the brake pedal of my 89 had a problem (poor intermittent contact from use/age) and was causing the torque converter (automatic tranny) to drop in and out of "lock up". The same switch also drops the cruise control out since the cruise module "sees" the brakes have been applied....so it drops out of "cruise". Check/adjust the switch on the brake pedal for a better swipe.
You can check the brake pedal cruise part of the switch (and clutch swith if manual trans) and cruise cut off relay contacts by measuring across pins A and G on the cruise module. Its just a series circuit but checks out many connectors and lots of wiring in a big loop. This gave me less than 1 ohm and when I pressed the brake pedal it opens up. I did it 15 times and it always came back to the 1 ohm indication. So that all looks good at this time.
I am also ruling out a EBTCM or a brake event that would open the cut off relay. If that happened my relay servo voltages would be “0” volts, not partial voltage.
Now I just have to drive the car again an get some more data.
Good luck and keep us posted. Nice and comprehensive thread
-Dave
Now driving the car this week as I said I am monitoring pins A and G with separate volt meters. The results got interesting. The main voltage for the module pin A always remained 12+ volts when problem occurred. However pin G (servo voltage input) dropped to 6 volts when problem occurred instead of the normal 12 volts.
This shows that the power switch, even though has some resistance in it is working satisfactory but not the problem. This throws me back into the brake pedal switch and cruise relay. This is the circuit that previously checked 1 ohm (pin A to G).
So now back in the garage I start checking that circuit again. This time it starts measuring 5-10 ohms as I step on the pedal. I switched the meter from ohms to continuity/ beep test mode. It started measuring from 6 ohms up to 90. As I switched back to ohms I got a high resistance reading.
I believe what’s happening is the switch is breaking down under load. The continuity test put a bit more current thru the contacts than the ohms mode. When the servo relays kick in that really pulls some current where the switch has a big voltage drop across it. Maybe this is the problem but until I get the switch out to check it nothing is certain. Probably should try the new cruise module when it get here just because its all apart already.
Don’t want to pull to much more apart, still have to drive the car to work. Aside from that the wife can't get in it any more due to the mess with things hanging.
Component side of cruise circuit card with clip leads.
Meters to monitor test points.
We do not have the 95-100 temperatures so car is not as hot as it was and duplicating conditions are different now.
Sounds like I am heading in your direction.
I re-focused on the brake pedal switch as it looked like the problem now. Took it out of the car and measured the suspect contact. The resistance did not look to bad but it has been fooling me for a while now. I opened the switch and found out all the contacts come right out. The cruise set of contacts did not look to bad, but the other two had some burn makes were there had sparked due to a higher current draw.
Took them all out, cleaned them all up and re-installed the switch. Drove for a couple days and all seems to be good. Going to get that sucker back together now and move to the next problem.
Here is a pix of the switch as I was taking it apart. All contacts just pull right out. Saved about $45, don’t tell GM, hope it holds up.
Thank you for a great write-up...Whereas we don't have any problems with our 94's cruise now, if we ever do, I now know exactly where to look...
Another wonderful example of the many great members on this forum willing to share their knowledge and experience...
Most of the time the check valve is visually broken, falling apart or has cracks in it. If your vents in you’re A/C are operating OK, and the check valve looks basically in tact, then the problem is probably some where else.
