engine balance
Old Sep 16, 2009 | 06:10 PM
ekess744's Avatar
ekess744
Default engine balance
Is it possible for my rotating parts to have actually been balanced if the connecting rods are still in a sealed in plastic?
Old Sep 16, 2009 | 06:25 PM
pr0zac's Avatar
pr0zac
yeah.. they weigh and match weights of parts.. then balance the crank according to piston and rod weight
Old Sep 16, 2009 | 06:52 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Assuming the rods are in their original packaging, then I don't see how any balancing was ever done. Generally during balancing there will be some metal removed from the big and or small end of the rods.
Old Sep 16, 2009 | 06:57 PM
ekess744's Avatar
ekess744
yes original packaging
Old Sep 16, 2009 | 07:11 PM
pr0zac's Avatar
pr0zac
can't you buy matched sets? i mean we are in the 21st century here. i don't see why they wouldn't come that way to begin with.
Old Sep 16, 2009 | 07:18 PM
ekess744's Avatar
ekess744
it's a box eagle sir bushed rods. I am just wondering because the guy said he computer balanced it with and sent a print out but he seemed kinda sketchy
Old Sep 16, 2009 | 07:42 PM
rklessdriver's Avatar
rklessdriver
Those rods come in weight matched sets (within 4 grams).
Run of mill performance parts usually come in matched sets to with in 4 grams from the mfgr. 1st quality stuff comes within 2 grams from the mfgr.
It depends but most performance shops try to get the parts used in a racing engine with in at least 2 grams (on all rotating parts).... Some shops go well beyond that to .5 a gram.... Some shops figure 4 grams is close enough on lesser engines.
A lot of shops also cut corners by taking the weights listed on the "balance card" that comes with the rods from the mfgr when figuring the bob weight. They SHOULD actually weigh them to verify - but like I said, everybody has their own idea of what "good enough" actually is....
Will
Old Sep 16, 2009 | 08:02 PM
ekess744's Avatar
ekess744
I was mostly wondering if the could have been weighed in the plastic or would that be highly unlikely?
Old Sep 16, 2009 | 08:14 PM
Big Jay E's Avatar
Big Jay E
We sell only Carrillos and you can go by their weight card. Don't know about the Chinese rods.
Jay
Old Sep 16, 2009 | 09:15 PM
rklessdriver
If they are stillall sealed up its Unlikely. The bag alone probally weighs 6-8 grams. Impossible to get accurate weight that way.
To calculate your bob weight you need 2 things from the connecting rod. 1. total rod weight and 2. the "big end" weight to calculate the "recripricating"... to get that you have to put the rod on a special fixture, kinda hard to do in the bag.
Will
Old Sep 17, 2009 | 03:42 PM
ekess744's Avatar
ekess744
that's what I thought
Old Sep 17, 2009 | 06:01 PM
bomar76's Avatar
bomar76
Hope he kissed you 'cause he sure as hell screwed you.
Old Sep 17, 2009 | 06:11 PM
rick lambert's Avatar
rick lambert
Many years ago, but my builder not only weighed them all, but measured each one too. Can't rem,ember how many he rejected, but it surprised me, not because of weight but because of dimensions.
Old Sep 17, 2009 | 06:15 PM
MK 82's Avatar
MK 82
If each rod was not weighed, it was not done correctly. That could have been done before they were packaged. If that is the case, there would be a weight card.
Old Sep 18, 2009 | 08:58 AM
ekess744's Avatar
ekess744
shockingly, all piston and rod weights ended up within a gram when checked by my builder
To engine balance
