What Engine to Build?
Old Oct 3, 2009 | 10:41 AM
Pete K's Avatar
Pete K
Default What Engine to Build?
Old Oct 3, 2009 | 11:53 AM
Redvette_22's Avatar
Redvette_22
One of our guys at the Corvette Challenge series at Etown, NJ is running a "stock" cube block in his 89, TPIS ported "113" heads, TPIS cam, TPIS Mini Ram, Hooker headers into Hooker Y pipe thru Flowmaster mufflers, Dana 44 w/3.73's and a high stall converter although I don't know stall speed or brand, and he runs 11.2's @ 121 in the cooler weather and 11.4's @ 119 in the summer. I know your combo is different, cubes and such, but he drives the car from NY to NJ for each race and still gets the performance area your looking for. A combination of both should easily get you where you want to be.
PM sent
Old Oct 3, 2009 | 12:14 PM
engle1147's Avatar
engle1147
PM sent
I think that would be Vic's car.
Pete:
Sounds like you may have "sprayed" the rings on the old motor a little too much. Hone it, re ring it, or sell it as a low 12's motor that needs ring/bore work.
1 vote for the 406 install.
Old Oct 3, 2009 | 01:31 PM
engle1147's Avatar
engle1147
Originally Posted by Pete K
Unfortunately, I did not have a chance to spray this motor.
When I first assembled it, I got about 100 miles on it, and a defective crank came to light. I ripped it down, swapped the crank, and put it back together. The rings never did seem to seal right.
Wow - sucks to have to tear a new one down again....been there done that. Few years back, had just finished an engine rebuild and was minutes from dropping it in the car. The engine was up on a rolling engine hoist had a local neighborhood kid come over and lean/pushed on it and the whole thing fell foward from about 3' high and bent the crank snout upon impact
Were the bores deglazed properly?
Old Oct 4, 2009 | 08:37 AM
danno85's Avatar
danno85
Pete,
Before you build another engine, or go back through the one you have, I'd like to help you with the blow-by problem. I've had similar experiences. I originally built a .060" over 350 for my '85. It made great power (346rwhp), ran hard, etc., but I had excessive blow-by. It smoked, burned oil, the oil got black quickly after a change, etc.
Well, I resolved the issue. I'll send you a PM.
Dan
Old Nov 16, 2009 | 08:17 PM
Tom 35th anniversary's Avatar
Big Block....I'm just sayin......
Old Nov 16, 2009 | 08:41 PM
STL94LT1's Avatar
STL94LT1
Another vote for the 406. After reading about your build, I just assumed it was going in the car. I'm axious to see how it runs.
Old Nov 17, 2009 | 12:22 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
None of the above. Go on a vacation young skywalker to HAWAII, and rebuild a transmission for Steve40th.
J/K
406 with AFR. My 2 cents.
Old Nov 17, 2009 | 02:49 PM
conv90's Avatar
conv90
It definately is going in. 406 with 195 AFR Eliminators and the superram.
Not till spring, but without a doubt 406. On paper, it is a winner. We'll see once it is in and tuned.
I Pete, I vote for a new 396
You are an expert on 396 ci SBC. Mine has never burned a drop of oil.
-Beppe-
Old Nov 17, 2009 | 03:57 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
How about the Jeb SP instead of the SR? I'm thinking it may soften it up down low and add some toward the top, the overall effect being a flatter, broader torque curve.
Old Nov 17, 2009 | 04:40 PM
dizwiz24's Avatar
dizwiz24
Build a 355, forged internals, ported AFR 195 heads, moderate cam (with a tad more duration on the exhaust side) .
cubes and gears won races 20 years ago, not today.
psi boost wins races today.
elsewise why do 4 cylinder evo's run 11.3@122 MPH and beat me.
If you go big cu. inch, go forged internals, and a moderate 9.5:1 compression ratio so you can slam 14 psi into there - if funds permits for an S/C in the future.
Seriously, invest some money in the stock market, real estate, or something and go boost. There is no other way.
Old Nov 17, 2009 | 09:52 PM
steven mack's Avatar
steven mack
My vote is for the 406 with AFR'S thats what I am building right now.I plan on running the Holly Stealth Ram on top.
To What Engine to Build?
