LT4 vs. LT1
Old Oct 29, 2009 | 11:21 PM
  #61
resipsa's Avatar
resipsa
Originally Posted by 8000RPM
Indeed the rods are the same. The LT4 rings were changed to help stop the 'supposed' ring flutter that was seen on a small percentile of LT1s. I forget what year I think 94 the rods were upgraded?
I stand corrected about the rods. They have the same part numbers. I've read about quite a few instances of spun rod bearings in LT1s that have been reved beyond 6100 rpm. I believe that the main reason for this is the tight rod bearing clearances and perhaps the rod bolts. Why is this not a problem with the LT4s or is it?? I have a cam, beehive springs, roller rockers, etc. in my LT1 and I do not rev it past 6100 rpm. The engine feels like it still has more power past this point but I am reluctant to rev it higher. I am I being to conservative with the rpm?
Back on topic, I definitely prefer an LT4 over the LT1. Its was the state of the art in GM LTx design. Why not buy the best of the breed.
Old Oct 29, 2009 | 11:24 PM
  #62
pr0zac's Avatar
pr0zac
Originally Posted by gaeecho9r
.just put the lt4 hotcam and 1.6 rockers in the lt1 and boom an auto lt4 basically,,,,,,,,,,,,,,,
basically you do not have an lt4.. you have a lt1 with a cam from gmpp. if you had an lt4 you would have lt4 heads, cam, intake, pistons and crank.. so yeah.. you basically have a lt1 with an aftermarket cam.
Old Oct 29, 2009 | 11:37 PM
  #63
reoch999's Avatar
reoch999
Not that there's anything WRONG with that...
Old Oct 29, 2009 | 11:45 PM
  #64
pr0zac's Avatar
pr0zac
never said there was.. just correcting a false statement.
Old Oct 30, 2009 | 12:37 AM
  #65
reoch999's Avatar
reoch999
it's all good. I still say someone should buy an LT4 and trade me heads & intake. I wouldn't have a real LT4, but I'd settle for a hybrid. (not talking gas/electric)
Old Oct 30, 2009 | 01:04 AM
  #66
94vettelover2's Avatar
94vettelover2
Those red intakes look cool.I know I said this before & plan on having an LT-4 intake when engine is upgraded.As far as heads I'll have the cylinder head shop guy that does work for our shop do the headwork(port & polish,upgraded valves,springs,& cam suggestions).When that time comes will also ask questions on this forum.You guys are awesome.BTW a porsche boxter S owner came in to our shop & asked me questions about his cars.He was a nice fellow who was down to earth & asked if I wanted to take his car for a ride.I did,thought it was nice but liked my vette better.I asked if he was a member on a porsche forum.He said yes but most members were more interested in keeping car shiny & not much technicial questions.THAT WOULD SUCK being a member & talking about car soaps & waxes all the time.Even if your a member here on corvette forum & don't fix your own car I'm sure your a car freak like the rest of us,& thats all that matters.I live,eat,breath,&...... cars in general.Even after work I still read about cars,internet,etc.This is a sickness,but I love it.
Old Oct 30, 2009 | 01:11 AM
  #67
pr0zac's Avatar
pr0zac
you realize that an lt4 intake will not fit lt1 heads?? besides that they have the identical port to an lt1 intake and offer no gains in stock form.. they are just able to be ported to match the lt4 head's port.
Old Oct 30, 2009 | 01:13 AM
  #68
pr0zac's Avatar
pr0zac
early lt1s had different rods then the later engines.. i think it was 95 that they changed them.
Old Oct 30, 2009 | 10:22 AM
  #69
rickneworleansla's Avatar
rickneworleansla
As we all know it doesnt take long before stock performance sucks. If modifying to drag race the number behind the LT means little. The things I like about the LT4 are the stronger dana 44, more porting potential in the heads, and the higher rpm tach.
LT1's can come with the auto which is better for drag racing when built right. Aftermarket heads and stronger rear can be added. The LT1's are slightly less expensive to purchase and easier to come by. I've also heard OBDI(pre-1996) is better for passing emissions in some states.
Both cars are great Corvette's to own. IMO
Old Oct 30, 2009 | 10:32 AM
  #70
rickneworleansla
I don't want to recommend anyone else to do what I do but...
My shift points are currently set to 6400 rpms.
Old Oct 30, 2009 | 05:56 PM
  #71
reoch999's Avatar
reoch999
I thought the intake port was higher on LT4 heads? You're saying the LT1 and LT4 intake manifolds have the ports in the same place? Or just that they're the same shape & volume, but different location?
Old Oct 30, 2009 | 06:02 PM
  #72
STL94LT1's Avatar
STL94LT1
The only difference is the LT4 intake has more material on the roof of the ports for porting. But, stock the LT4 and LT1 intakes have the same port dimensions and locations.
Old Oct 30, 2009 | 06:07 PM
  #73
5abivt's Avatar
5abivt
The LT4 ports are the same as the lt1. the casting is raised to be in a higher location to match up with the raised ports on the cylinder heads. There is nothing special about the manifold.
about this special lt4 dana 44
Old Oct 30, 2009 | 06:46 PM
  #74
94vettelover2
Really?Well I'll just port/polish the extra intake I have & paint it red.
Old Oct 30, 2009 | 09:21 PM
  #75
reoch999's Avatar
reoch999
My shift points are set at 6000. Last time at the track, I experimented a little with holding it in gear longer and trying to make it shift right before it hit the 6400 RPM limiter and got slightly better corrected ETs. I want to get some time on the dyno and some datalogs first, but I'm probably going to raise the shift point to around 6300, and the limiter to 6500.
Old Oct 30, 2009 | 09:35 PM
  #76
reoch999's Avatar
reoch999
I don't think there's anything special about the D44 in the LT4 cars, I think he was just highlighting the fact that since LT4 was only in stick shift cars, they all had D44 as opposed to the auto cars with D36.
Prozac, correct me if I'm wrong on this one.
About the ports being the same on the manifolds... Wow. So then on the LT4, is there a "step" between the intake port on the manifold and the intake port on the head? Or are the intake ports the same on the heads too? I always thought the LT4 heads flowed better because the top of the intake port was higher, increasing intake port volume and flow, and a raised exhaust port allowing increased exhaust flow. I guess I just ASSumed that meant the intake manifold would match.
Guess Weird Al was right, everything I know is wrong...
Old Oct 30, 2009 | 09:38 PM
  #77
STL94LT1's Avatar
STL94LT1
The intake ports are higher on LT4 heads, they don't match the intake.
To LT4 vs. LT1
Old Oct 30, 2009 | 10:46 PM
  #78
reoch999's Avatar
reoch999
Thanks. I think I understand now. So if a guy put an unported LT4 manifold on a new set of AFR 195 LT4 style heads, it would be the same as an unported LT1 manifold. But the LT4 manifold COULD be ported to match while the LT1 manifold wouldn't have enough metal to port match without compromising the port "roof."
Old Oct 30, 2009 | 10:58 PM
  #79
STL94LT1's Avatar
STL94LT1
I'm pretty sure the new AFR 195 Comp heads will work with either the LT1 or unported LT4 intakes. Jim Mason "96GS#007" sold his ported LT4 intake and bought a new LT4 intake for his 383 build with the Comp 195's.
Old Oct 31, 2009 | 03:53 AM
  #80
slickfx3's Avatar
slickfx3
Default anothet LT1 LT4 explanation
Little history of the C4 Vette
Oh and a little bit of C5 action
