c-4 voltage dropping
Old Nov 3, 2009 | 12:58 AM
donkeydawn11's Avatar
donkeydawn11
Default c-4 voltage dropping
Hi again
Im having a problem with my voltage at idle I can see the voltage drop from 14.2 or 14.3 to 13 and sometime lower. It seems to only do this at idle and in drive or reverse. Wires plugs just replaced
any suggestions I have no codes
sorry 1994 c4
Old Nov 3, 2009 | 01:40 AM
86PACER's Avatar
86PACER
What's your idle speed?
Old Nov 10, 2009 | 10:13 AM
donkeydawn11
Default voltage drop
about 1k could this be a split in one of the spark plug wires
also I forgot to mention that Im getting a knocking noise from the drivers side which sounds like a lifter would that be the problem.
Any suggestions at this point would be useful thanks again.
Old Nov 10, 2009 | 11:31 AM
pcolt94's Avatar
pcolt94
Originally Posted by donkeydawn11
Hi again
sorry 1994 c4
I’m not really sure you have a problem. After running for a while and with the battery fully charged, the voltage will reduce. And if your headlights or A/C is running hard, I have seen my own voltage go the 13.8 or .9 at a light and holding my foot on the brake. After I get going it comes up to maybe 14.1 or so.
Now if you are dropping below 13.5 volts, that may cause reason to pull out the DVM and give it a check at the battery.
I happen to know my displayed voltage is about 0.3 – 0.4 volts higher than the actual battery voltage as read with a DVM. The CCM is not an accurate voltmeter but this is what’s right for my car.
Old Nov 10, 2009 | 12:02 PM
engle1147's Avatar
engle1147
I've also seen may an instrument cluster with a voltage reading that was off by as much as + or - .5 volts. If it gets down below 12 VDC.....you may have an issue. Typically a car only needs a minimum of ~ 11 VDC to continue running - after being started.
Old Nov 10, 2009 | 12:19 PM
jfb's Avatar
jfb
The alternator output (dash voltmeter, engine running) is 14.3 volts cold and this drops to 13.3 volts hot and is normal. The dash voltmeter reads low and is not accurate if the alternator is not charging the battery. It sounds to me that your alternator needs repair or replacement. The dash voltmeter reads low by 0.3 volts because it reads the voltage after the ignition switch contacts which have about 0.3 volts drop. You might check the voltage across the battery terminals. Very low idle rpm, below 600 rpm, will greatly limit the alternator output current and in current limiting the alternator output voltage will be low. A battery that needs recharging can also cause high alternator current. You can tell the state of charge in a car battery by measuring the no load voltage at its terminals, 12.0 volts and below, discharged and 12.9 volts and higher, fully charged and linear in between.
Old Nov 11, 2009 | 10:19 AM
ronniebfla's Avatar
ronniebfla
I have the same problem. did you change your pulleys? or put in an under drive? does your battery have a tight connection on the posts?
Old Nov 13, 2009 | 11:07 AM
donkeydawn11
I did change the pulleys
i did change the ujoints on the drive shaft battery and alt are new and tight connection are made.
No change it affects the idle
also i noticed today that my normal idle is 500 this is when you see the voltage jumping. when driving at rpms of 1K to 2K I get a very bad hesitation. If i step on the gas hard and go past 2k rpms it doesnt happen.
Old Nov 14, 2009 | 08:49 AM
pelensky's Avatar
pelensky
I had a similar problem and found a couple of loose ground and positive terminals. Check especially the one at the rear bell housing and ground strap that goes from the bell housing to the drivers side frame. Clean them with sand paper and retorque.
Old Nov 15, 2009 | 10:18 AM
jfb's Avatar
jfb
You changed the pulleys to what? If you changed the pulleys that causes the alternator to turn slower, then the alternator isn't turning fast enough at idle to be able to operate your electrical system and the battery is supplying all the power. This will cause low battery voltage. Also, 500 rpm is lower than stock and probably too low to allow the alternator to supply power to your electrical system.
To c-4 voltage dropping
